Tires & Rims help
Subscribe
Nov 17, 2006 | 09:52 PM
Does anyone know what the ride would be like on the stock struts and springs with these rims...... By the way these are the same rims in my sig pic and you can find more pics.
rims - 19"
offset - 40mm
front tires - 255/35/19
rear tires - 275/35/19
Reply 0
Nov 18, 2006 | 05:36 AM
I assume with that thin of a sidewall the ride would be a bit rougher, even on the stock suspension. On smooth roads you probably wouldn't notice the difference.
Reply 0
Nov 19, 2006 | 04:30 AM
Yeah that sucks considering nyc is all potholes and bumps unless you go more towards long island
Reply 0
Nov 19, 2006 | 09:46 AM
Quote: Does anyone know what the ride would be like on the stock struts and springs with these rims...... By the way these are the same rims in my sig pic and you can find more pics.
rims - 19"
offset - 40mm
look at my sig, that's pretty close to what I have... on an SC though, those tire heights are actually too tall... the rear is about an inch diameter bigger than stock... 275/30-19 would be a better fit... same for the front, a 235/35-19 would be a much better fit...
19's are a pretty stiff ride... I love it... but you definitely feel pavement imperfections...
Reply 0
Nov 19, 2006 | 04:12 PM
It looks like you're still on your stock shocks and springs....?
Reply 0
Nov 19, 2006 | 09:19 PM
Quote: It looks like you're still on your stock shocks and springs....?
me???
1.6" lowered on tein s-tech springs and supra TT struts....
Reply 0
Nov 30, 2006 | 07:29 PM
bump ^ TTT !
Reply 0
Dec 8, 2006 | 05:35 PM
any other responses?
Reply 0
Dec 12, 2006 | 06:20 PM
Bump Bump Do 20's Fit On The Car With Stock Suspension Without Rubbing?
Reply 0
Dec 12, 2006 | 06:51 PM
^ depends on the full specs of your rims, but the general consensus is yes....stock ride height is pretty high.
Reply 0
Dec 12, 2006 | 10:53 PM
Quote: ^ depends on the full specs of your rims, but the general consensus is yes....stock ride height is pretty high.
correct... 20x8.5 with a 225 or 235 width tire will fit all day any day with +35- to + 45 offset....
235/30-20, 225/30-20, 225/35-20 would all be in the appropriate range with no fender mods or anything on the above setup...
Reply 0
Dec 14, 2006 | 06:35 AM
i think 20s will be too much. stick with 19s go in the low 30s with the offset and you should be fine
Reply 0
Subscribe
