Could it be.....Turbo?!
Old Oct 20, 2001 | 08:00 PM
CmputerWiz's Avatar
CmputerWiz
Oh and some new pics...
When putting the throttle body back on, make sure you:
A: Tighten all bolts a LOT
B: Zip tie all vacuum hoses so they don't pop off under boost
C: Reconnect that antifreeze hose that is nearly impossible to get to
D: Make SURE you put the gasket back in BEFORE you do A,B,C. (please note gasket in following picture, and the fact that A,B,and C are already complete)
DOH!!
Old Oct 20, 2001 | 08:13 PM
CmputerWiz's Avatar
CmputerWiz
Here's the oil feed line that goes to the turbo. If you look at your oil filter you'll see a LARGE bolt beside it. You gotta pull out that bolt, drill it, and then tap it for the connector. Luckily Lance had an extra bolt around, so I had him go ahead and tap that one, and I sent mine back to him. That saved a lot of trouble!!
Old Oct 20, 2001 | 08:15 PM
CmputerWiz's Avatar
CmputerWiz
And here's the oil return fitting. It's the blue thing at the bottom there. Theres a plug down on the block, you just drill it out and tap it. MUCH easier said than done.
Old Oct 20, 2001 | 08:18 PM
CmputerWiz's Avatar
CmputerWiz
And you have to remove the oil pan also, to get the metal shavings out. Easy right? Just an oil pan?
Well it would be easy, if it wasn't for the fact you have to remove the rear subframe of the front suspension, which in turn destroys your alignment. I now know why a Lexus lasts forever...because they're impossible to work on!!!!!!!!!!!!!!!!!!!!!!
Old Oct 20, 2001 | 08:20 PM
CmputerWiz's Avatar
CmputerWiz
And the intercooler piping/intake piping. Painted it with 1200deg paint that matches the car. I'm still trying to figure out how to fit the long pipe in the oven to bake the paint on....hmmm. For now the grow light....errr....I mean heat lamp is heating it. Notice the fittings on there for the additional fuel injectors....n.e.a.t.o.
Old Oct 20, 2001 | 08:24 PM
CmputerWiz's Avatar
CmputerWiz
Here's the intake piping with the blow-off-valve installed. Thats the HKS Super Sequential BOV....looks and sounds better than the rest. Hope it works good too.
Old Oct 20, 2001 | 08:29 PM
CmputerWiz's Avatar
CmputerWiz
No more Zex for me. Damn. Gotta go with a wet kit from now on, the dry one could hurt it now.
Wait, are we talking about the car still?!
Jeff....whatta ya think of me getting a 300ZX TT nitrous kit...that has two solenoids, and put one jet into each side of the manifold where the intake splits to a "Y"?? Lance was talking to me about that....god I would hate to have to take that side of the intake off tho...its connected to the injectors somehow.
Got a name of someone at NX that I should talk to about it?
SR
Old Oct 20, 2001 | 08:33 PM
CmputerWiz's Avatar
CmputerWiz
Now that's just too cool. The SC300 already has the mounting holes for the side-mount intercooler. Odd...maybe they make a turbo version of it somewhere in the world? (damn those lucky aussies and brits)
Looks like I need to clean the underside of the car....I see a "little" overspray from when I painted it. No matter....when the wheel is back on ya can't see it.
Notice the small front brakes....well only until tomorrow. Once I get the car to start again, I'm gonna switch out the brakes with the big ones!
I also found the limits of my Optima red-top battery. Two days of playing the stereo cranked, and it's dead. Can't believe it lasted that long with these amps!
SR
Old Oct 20, 2001 | 08:43 PM
CmputerWiz's Avatar
CmputerWiz
And what is it with these cops. Always stereotyping people in modded cars, saying we're drug dealers, say we're breaking the law all the time.
Glad it was only my dads car. My favorite dialog with him today was
D: "Is it legal for you to remove your catalytic converters in Florida?!"
Me: "Yes dad, of course! I wouldn't want to do anything illegal!"
D: "What about that external wastegate, that will blow the exhaust directly out of the manifold, causing flames to shoot out from under your car, sounding like a large jet coming from your engine bay, and blowing terrible fumes at anyone nearby?"
Me: "Well that's legal too, we use it to scare the alligators out from under the car, and to prevent us from getting carjacked."
D: "Let me guess, Florida is one of those states that doesn't do a yearly vehicle safety inspection?"
Me: "Bingo."
D: "What about an emissions check?"
Me: **points to the catalytic converters sitting on the ground, never to be installed again**
D: "Nevermind. Just don't try having the Florida trooper call me to get you out of a ticket or jail."
heh
SR
Old Oct 21, 2001 | 06:03 AM
SC300TURBO's Avatar
SC300TURBO
looking good..not too much more for completion....pipes look good.....and i hate having to do things twice...I.E.gasket.....keep on posting us about the completion..Jeff
Old Oct 21, 2001 | 09:23 AM
CmputerWiz's Avatar
CmputerWiz
Jeff....I'm stuck. The rubber air intake pipe that connects to the turbo won't fit. The distributor is in the way. I even removed the metal guard from the bottom of the distributor, still won't fit. I have to pinch the rubber intake pipe almost completely for it to close. Any advice? You got any pics of your up close?
Thanks!!
SR
Oh ya, I still can't get the filings outta the engine....hmmm....
Old Oct 21, 2001 | 12:31 PM
meanboy's Avatar
meanboy
Originally posted by hwallen172
Forgive my ignorance, but will an aftermarket turbo still pass emissions inspection? I wouldn't mind getting one, but I've got to pass inspection in Atlanta.
HAHA
It will never pass a visual in any state requiring one. Notice the cat connected to the exhaust manifold? Here today and gone tomorrow.
Notice the disclaimer when you purchase such a kit; "for offroad use only".
But then again, it's only money, so who cares?
Old Oct 21, 2001 | 12:52 PM
VeilsideRSPsc's Avatar
VeilsideRSPsc
ah brings back memories of my install... looks great and good luck!
-brian
'92 turbo veilside rsp sc300
team koncept racing
hyper racing
team toyo
valvoline
apr performance
Old Oct 21, 2001 | 03:08 PM
SC300T's Avatar
SC300T
Wiz, it should be tight, but it fits...
Are you using the right elbow?
I used a little WD-40 on the hoses to help them slip on. You shouldn't have to take off the distributor nor the shield around the distributor.
I've got my digital camera batteries charging and I'll try to get a pic to you tonight.
Old Oct 21, 2001 | 03:15 PM
SC300T's Avatar
SC300T
You've got to find the plug... Also, you didn't have to drop the pan... All you had to do was lower it, move it back slightly and put a trash bag over it so that the filings don't get in it. Forget about moving the rear crossmembers.
On the filings... I just put my fingers in the hole, got most out by hand from both ends, then hooked up a shop vac to the hole just created. I then ran some cheap oil through the hole. I did an oil analysis on the first change and got virtually no metal found in the report of the oil, so my method worked fine. Make sure the oil return hose isn't too long. You don't want any slack in this hose, because it may be suspect to collapse if you have extra bends in this hose... I had a problem with this hose kinking up because I had left it too long. You just want it long enough to reach with a smooth curve to the block, no extra.
