engine problem
Old Oct 11, 2006 | 06:47 AM
ddr_6's Avatar
ddr_6
Default engine problem
ok when i start the car i hear a weird whistling noise coming from the engine but then after a while it goes away especially after i redline it but it is getting cold out now so could that be it? ne help u guys could give me on what it might be or what i could do 2 fx it would really help
Old Oct 11, 2006 | 08:54 AM
neurocity's Avatar
neurocity
Not quite my tempo
Pop the hood...
Have someone start your car.
Look/listen to where its coming from.
Let us know before 3pm today
...or we wont help you!!
This will be moved soon...
Old Oct 11, 2006 | 09:04 AM
JohnEd's Avatar
JohnEd
Default noise
I had the same problem a couple of times. Once it turned out to be the belt "squeaking". Get some "belt dressing" and rub the stick against the serpentine belt as it runs. Do both sides. You do understand that the belt will CUT OFF anything you let get caught in a pulley. Suggest you don't use anything more important than your fingers to apply the stuff.
Next, get a 3 dollar stethoscope from Harbor freight and "listen" to the bearings. Two of the mounting bolts don't turn. Listen to the AC, alternator, power ster pump and the hyd fan pump.
It is most prob the belt. And, I think they also have an aero can spray of the stuff.
Good hunting.
John
Old Oct 11, 2006 | 09:29 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
You missed all the hints and indicators there was an engine forum.
moved
Old Oct 11, 2006 | 05:20 PM
over40driv's Avatar
over40driv
Uh, moved where, this is the engine forum, isnt it?
Old Oct 11, 2006 | 06:16 PM
jibbby's Avatar
jibbby
Banned - could not follow forum rules
Belt dressing will only temporarily take care of the noise, it will come back...A new serp belt is needed...Water pump pulley could be squeeling too...You need to listen or spray a little lube in each area to find the location of the problem if it is something other then the belt.....
Jkappel84
Apr 29, 2023 07:48 PM
LEXUSRUNIT
Apr 29, 2023 07:45 PM
maximakid
Mar 18, 2013 07:42 PM
carcass66
May 12, 2004 05:37 AM
Purdy99
RX - 1st Gen (1999-2003)
Mar 18, 2004 03:27 AM
