TPS questions?????
Old Oct 5, 2006 | 04:26 PM
SimplyZBes's Avatar
SimplyZBes
Masterhater
Default TPS questions?????
I just bought an SC400 and just realized that it has no power at all. Could this be the TPS? The dealer told me the car uses 2 of these. How do you test to see which one is bad? All info will be greatly appreciated.
Old Oct 5, 2006 | 04:28 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
engine question, engine forum. Moved
Likely your cause. I test mine with a snap on scanner.
Old Oct 5, 2006 | 04:34 PM
SimplyZBes's Avatar
SimplyZBes
Masterhater
Default TPS Questions????
Sorry about that O.L.T. I made a mistake posting in there. When you say you use a scanner to test yours, what do you mean? How do you test it? Do you know exactly where they are located on the '95 SC400?
Old Oct 5, 2006 | 06:34 PM
jibbby's Avatar
jibbby
Banned - could not follow forum rules
I am only aware of one Throttle Position Sensor...It just plugs in...Clean the leads and try that...I dought that is the problem...No power means you could have restricted exhaust or an electrical problem of some kind.. Where does the car experience no power....If it is only happening from a dead start that is the stock torque converter and that is normal...Slow takeoffs in the SC4's
Old Oct 5, 2006 | 06:43 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Gotta intervene here Jibby, the TPS judges the position of the gas pedal and on my scanner you can watch the pedal steps (0-5) as you depress the pedal. This is the TPS telling the scanner (and the car) where the throttle is.
When one goes bad, you only get like a step 2 at best. and the remaining 3 steps of the throttle are never achieved. Even if the throttle opens via the gas pedal, the MAF and O2's are still at minimum flow, as well as the injectors.
Old Oct 5, 2006 | 06:54 PM
SimplyZBes's Avatar
SimplyZBes
Masterhater
Default TPS Problem???
Torque converter? That does not sound right to me Jibby. I had the same problem with my old 2000 Maxima and to solve that problem, I changed the tps and all the power came back. O.L.T is probably right and I will go and get the (2) TPS sensors. Is there any possibility that a blocked up converter could cause such a severe loss of power? The car does not even sound like an SC400, it sounds like a dead 4 cylinder car.
Old Oct 7, 2006 | 02:09 PM
jibbby's Avatar
jibbby
I did own a car dealership for several years and have maintained and repaired these cars over and over again....Pretty much have seen it all...I experienced these types of problems many times on over 50 Sc400 and Ls400 and the TPS was never the problem...Dirty throttle body caused a bouncing or irratic idle...Loss of power clogged cats, or an electrical problem..Just my two cents....
At stock these cars have a very weak stall rate torque converter that makes these cars very slow at take off...Designed for old folk.....That is fact.
Old Oct 18, 2006 | 05:07 PM
SimplyZBes's Avatar
SimplyZBes
Masterhater
Talking SimplyZBes
I found the problem and fixed it. One of my coils were dead. I replaced it and the car runs as a true SC400 V8 should. Thanks Jibby and all the guys that responded to this thread in attempt to help me find the problem.
Old Oct 24, 2006 | 03:22 PM
deruvian's Avatar
deruvian
Slightly off topic, but is it just me that instantly thinks of Office Space when reading anything about the throttle position sensor (TPS)?
Old Oct 24, 2006 | 03:39 PM
laxdude362's Avatar
laxdude362
TPS reports!! LMAO!! I love that movie!
Old Jan 9, 2008 | 09:22 PM
stonewis's Avatar
stonewis
Ummm, my SC400 has two throttle position sensors. Actually one is a 'throttle position sensor' and the other (right next to it) is called the 'sub throttle position sensor'. My SC has Traction Control and from what I've read they are the ones that have TWO of these sensors. But, I've never owned a dealership....
Penthos
Aug 16, 2014 09:06 PM
chrisindub
Jun 7, 2012 06:11 PM
guod
Aug 21, 2009 08:26 PM
ojas
Jun 21, 2006 08:05 PM
