KYB AGX shocks for SC300??
since you mention it.......i have KYB AGX shocks on my car...but hteres a trick....
i bought the shocks for a toyota supra....so all 4 shocks are for a supra..
springs are eibach pro kit..
front are sc300 springs
rear are toyota supra tt springs....
got it?....it works well.....i like em..Jeff
i like them alot....i did it because i wanted to have adjustable shock to help in my wheel hopping troubles...they seemed to have worked very well...Jeff
definitly helped body roll...if you want to spend more cash you can goto the Tein coilovers........also a supra rear sway bar help body roll...i have VERY little bodu roll on my car now...
I used to have KYB AGX's on my Accord. Loved them. I can't say much about reducing body roll and things like that. I think my Eibach Sportlines took care of a lot of the handling issues. But the AGX's are really nice because you can make your ride stiff and bouncy as hell or nice and easy like stock. I'd get them. I was considering getting some AGX's for my SC300 with stock springs, but I don't know if that's gonna do much for handling. Is that what you're planning on doing?
Did the Supra rear sway bar require modifications to install? You got the factory sway bar? Thanks.
you need the sway bar and rear subframe mounts.....i used the stock supra bar...
1. Eibach lowering kit for SC300.
2. KYB AGX 4 point adjustable shocks.
3. 18" rims with nice Z rated tires.
4. Supra TT breaks with bremo rotors (seposely that might work).
My Apexei S-AFC is on the way. I know that the HKS AFC is somewhat better, but I still like the design of the Apexei.
PS. Nice homepage howiedoit. What's up with the shoes section??
i dont have a front sway bar on my car......i have the factory front sway bar........i also have a factory intake manifold.....also if you are buying AGX shocks you will need supra rear springs....
and Brian.....yes you can add that.....lol...Jeff
Originally posted by VeilsideRSPsc
may i add that the teins are badass?
-brian
team koncept racing | hyper racing
houston, tx
'92 turbo veilside rsp sc300
/ team toyo . valvoline . apr /
-brian
houston, tx
