Joint Bolt?
Old Jul 20, 2006 | 03:50 PM
koolharsh's Avatar
koolharsh
Default Joint Bolt?
Mods, please delete
Old Jul 20, 2006 | 06:25 PM
95 Integra's Avatar
95 Integra
Im not really sure what a joint bolt is, maybe they ment ball joint?
Old Jul 22, 2006 | 08:18 PM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
Axle joint bolt.
I never heard of it either, unless its one of the 6 allen bolts the holds the axle to the diff.
To make it pull off alignment, ALL the remaining bolts would have to be loose on that
side.
Bet the Goodyear service manager & the tech had had no idea either. (Finger in nose,
'its that thing there' .... 'the whats it macalled thingey' )
Hope they wrote it down for you so you can clarify here. It could be important & we'd be
glad to help.
Old Jul 24, 2006 | 10:37 AM
congsc300's Avatar
congsc300
hey sup,
I have the same problem, and wonder what you do to fix it. My steering wheel is not stright when I drive. I also did my alignment, but they said it is my power steering. It also squeaks when i turn left or right all the way.
Old Jul 24, 2006 | 06:27 PM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
Originally Posted by congsc300
hey sup,
OMG, I need to open my own place. Just because your power steering pump is making
the death whine, it can't through off a wheel alignment. You can remove the pump & drive
the car. The steering wheel will be straight & not pull. Either something in the steering/
suspension is worn causing the pull, a tire is low on air or it's not properly aligned.
A competent alignment shop will tell you exactly what is worn & needs to be replaced.
The only things I can think of "power steering" would be Inner, Outer tie rods or
Rack bushings that would affect wheel alignment.
416tt
Mar 31, 2016 05:28 PM
chnk
Mar 21, 2011 10:32 PM
Agent$mith
Jan 10, 2011 05:39 PM
MIGS
Oct 29, 2009 04:39 PM
Rich27
Jul 26, 2005 08:54 PM
