Crank Pulley replacement fun
Old Jul 12, 2006 | 12:48 PM
SPORTcoupe's Avatar
SPORTcoupe
Default Crank Pulley replacement fun
Victim (Love the Craftsman warranty):
Cheater bar (battery for size comparison):
Some hood clearance:
Before:
After:
Any questions?
~Alan
Old Jul 12, 2006 | 02:24 PM
bens sc's Avatar
bens sc
are your before and after pics mixed up?
Old Jul 12, 2006 | 02:44 PM
SPORTcoupe's Avatar
SPORTcoupe
Nope.
~Alan
Old Jul 12, 2006 | 04:45 PM
soarer479's Avatar
soarer479
lol you will need a crank pulley puller tool or some impact tools haha i just did mine
Old Jul 12, 2006 | 05:03 PM
SPORTcoupe's Avatar
SPORTcoupe
Ended up getting a steering-wheel puller from Kragen (Checkers?) for under $10. It did the trick.
~Alan
Old Jul 12, 2006 | 05:59 PM
nasc300's Avatar
nasc300
This is what you need. Cost about $80
Old Jul 12, 2006 | 06:35 PM
SPORTcoupe's Avatar
SPORTcoupe
LOL...that picture makes it look so simple.
The ratchet in his right hand would need to be at least 2 feet long, while the one in the left, at least 4 feet. Then maybe he would get it loose.
Helpfull tool nonetheless.
I put the car in 5th gear and had a friend hold the brakes with choks underneath all 4 tires. It did the trick (probably thanks to the aftermarket clutch)
~Alan
Old Jul 12, 2006 | 07:36 PM
nasc300's Avatar
nasc300
It is simple with the tool.
But yes, you need to add extensions to the rachets, but one person can handle the job.
Old Aug 14, 2006 | 03:46 PM
sickid's Avatar
sickid
did you change the pulley due to excessive squeeling i noticed mine has no grooves and it looks like a buildup of rubber on the pulley. where did you get the new one and what type is it? i also noticed the tensioner has a metal pulley not the plastic one i have on my sc did you change that one as well also what type? thanks so much
Old Aug 15, 2006 | 10:33 AM
SPORTcoupe's Avatar
SPORTcoupe
Yes, it was squealing like crazy.
I replaced the tensioner pulley with one from a local car parts store because I thought that's where the noise was coming from.
My 'new' one is actually a used one from a fellow NA Supra owner.
They are pretty expensive new.
BoostLogic makes a lightweight replacement if you need the performance.
Good luck.
Cheers,
~Alan
Old Aug 15, 2006 | 08:33 PM
sickid's Avatar
sickid
thanks alot much appreciated
Old Aug 15, 2006 | 08:56 PM
trangk's Avatar
trangk
Where can I get this tool? I'm about to replace my crank pulley also and don't have access to impact tools.
Old Aug 16, 2006 | 03:24 PM
parker770's Avatar
parker770
I did this on monday when I did the timing belt and water pump. I just wedged a breaker bar against the frame rail and bumped the starter. It came off instantly, with no headache. I read about some people warning against this technique, but it worked perfectly for me.
Old Aug 16, 2006 | 04:11 PM
SPORTcoupe's Avatar
SPORTcoupe
Interesting. My starter made a few clicking noises, and then proceeded to smell like ***. That's about it.
~Alan
Old Aug 16, 2006 | 04:39 PM
eskinol's Avatar
eskinol
Interesting tool, but I think I'll stick with my 600lb torque impact gun. Works wonders Could remove and install literally in seconds ^^ Highly recommended tool for at home mechanics.
-esk
