Low Idle/Stalling Issue
The only problem I seem to be having with my car is that when I turn it on, the idle is very close to 0 RPM. Like, it's idling at 150/200RPM. Then occasionally when I reverse and stop abruptly, It will stall. NO Check Engine Light is on. I cleaned my Air Filter, and I Made sure my Mass Air Sensor is plugged in nice and good. What else can be the problem? My Power Steering Pump isn't leaking, I checked. What about the Fuel Pump ECU? Is that something I have to replace or ByPass?? How about changing the Fuel Filter?
Now, is there any way to check if my car had the Timing Belt and Water Pump changed? I went to Midas to service my vehicle and they said they would check to see if anything was wrong with the car and they only changed my Oil, Oil Filter, Transmission Flush and Serpentine Belt. They didn't even change my Transmission Filter, Brake Fluid, Coolant flush, etc. Isn't that supposed to be part of a 150,000 Mile Service?? I'm starting to think twice about why I bought this car now ...
https://www.clublexus.com/forums/sho...d.php?t=224751
Yes, all the fluids should be replaced
I really hope it has been changed, I mean it had to of been, with 150,000 miles, because isn't it supposed to be changed around 90,000 and if not it would've probably broke by now. Is the Water Pump and Power Steering Pump supposed to be changed around that same time the timing belt is?My girlfriend says instead of changing the transmission mount, I should get the transmission overhauled...anyone ever heard of that? I keep having her hear the "clunk/thunk" sound my car makes at around 30 MPH when I let off the gas/apply the gas from a roll.
So far, I got my Oil changed and Transmission flushed. What are the other coolants that need to be changed? Brake fluid, Coolant, Radiator, what are the others? I'm planning to do them all myself.
Engine coolant / antifreeze with distilled water
Engine oil
Automatic transmission fluid
Power steering fluid
Dot 3 Brake fliud
Rear differential fluid
Windshield washer fluid
Who told you that? Sounds like BS to me. They should be able to pull any service history on your car that was done at any lexus dealer. My local dealer did for me and saved me alot $$. Talk to another service rep.
as for the stalling low idle, I'd try putting a paperclip in fp and b+ ports of the diagnostic port on the engine. That bypasses the fuel pump ecu. If everything works fine with it bypassed then replace or fix that pump ecu.
