Both rear side windows leak
Old Jun 27, 2006 | 06:12 PM
mousiee's Avatar
mousiee
Default Both rear side windows leak
i was aware of the little leak from the rear side window on the drivers side, but today I noticed a little leak from the passenger rear side window. Both leaks seem to be in about the same areas.
passenger side
drivers side
Has anyone else encountered this problem?
I plan to take her to the window shop tomorrow to have it fixed. I've already taken out the back seats.
Thanks
Mousiee
Old Jun 27, 2006 | 06:14 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Sunroof drains are clogged. Drop the headliner and repair. Window shop can't help you.
Old Jun 27, 2006 | 06:24 PM
mousiee's Avatar
mousiee
And all this time I thought it was the damn (excuse my french) side window trim letting water in.
Thanks for the advice.
Now I have to figure out how to drop the headliner w/ out messing up the interior.
Old Jun 27, 2006 | 06:33 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
remove everything you see.
rear mirror, pillar trim, visors, etc......
Old Jun 27, 2006 | 06:42 PM
mousiee's Avatar
mousiee
Oh my goodness. I was getting ready to take off the trim in the back but the screw where the fron seatbelts come out will not unscrew. I may have to bite the bullet and take the time and do it. I sure don't want to pay someone to do it; plus it sounds like fun.
Question: If the sunroof drains are clogged would the headliner get wet?
Old Jun 27, 2006 | 06:58 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
100% possible, but the roof has a natural curve to it so it tends to go to the sides. Once you remove the rear trim (do that first) you'll know where you are on the project.
PS- to remove the rear trim you have to pull the rear seat. the trim has a pop snap holding it in and the rear quarter covers have to come off first.
Old Jun 27, 2006 | 07:02 PM
mousiee's Avatar
mousiee
Thanks or all your help.
I've searched headliner and I'm looking at your post where you removed your carpet and pressure washed it with oxy clean.
Mousiee
PS- to remove the rear trim you have to pull the rear seat. the trim had a pop snap holding it in and the rear quarter covers have to come off first.
Old Jun 28, 2006 | 05:44 PM
mousiee's Avatar
mousiee
Today after work I removed the rear side panels and droped the headliner. I removed the tube fron the sunroof drain in the read and stuck a piece of habger in the holes to try and unclog them. It didn't feel like it was clogged but I hope that was the problem.
While I have the rear out I plan on taking the front seats and the center console out . I plan on shampooing the carpet really well, cleaning and conditioning the seats and panels while they are out, adding the a center console cup holder, and new emergency brake boot and shift ****. This will probably take some time, but I'm dedicated.
Wish me luck
Mousiee
Old Aug 30, 2006 | 08:40 AM
mousiee's Avatar
mousiee
Wish me luck
Mousiee
Apologies for bringing back an old thread, but I found the leaks to be coming from the rear side windows and not the sunroof drains.
Questions:
I assume by removing the four bolts the glass will come out w/ alittle help. Is this a easy DIY job, to take the glass out, seal, and re-install? Has anyone done this, and what type of sealant did you use when re-installing.
I went to a place that installs glass and they told me to do it they would charge $40-$50 depending how hard it is to get the glass out.
Thanks
Mousiee
Old Aug 30, 2006 | 10:51 AM
aliga's Avatar
aliga
Former Sponsor
Questions:
Thanks
Mousiee
glass guy will need to cut out the butyl glue, its a tough job.
Old Aug 30, 2006 | 02:49 PM
mousiee's Avatar
mousiee
So, basically let them handle it.
Once they get the glue out, they will use the same glue or will they use another type?
I think my rear windshield needs to be re-glued also. It sounds like cracking glass back there when I hit bumps or the chassis flews. The funny thing is, when it's raining or damp outside the cracking sounds goes away.
Thanks
Mousiee
jcoleman3
Aug 9, 2017 10:49 AM
Pianoman72
GS - 1st Gen (1993-1997)
Jan 29, 2007 05:39 PM
joegolf68
Apr 26, 2005 07:15 AM
anthracitetarga
Maintenance
Apr 7, 2002 11:37 AM
anthracitetarga
Apr 6, 2002 11:17 AM
