minor issue when pumping gas - sc4
Old May 20, 2006 | 08:24 PM
jb86's Avatar
jb86
Default minor issue when pumping gas - sc4
Just wondering if you guys have come across the same problem as me.
When I am filling up with gas the pump often stops midway and I have to keep adjusting the nozzle.
I have to fill up extra slow for it to stay pumping for some reason. Could this be a problem with the air holes in the tank...maybe they're blocked not allowing air to the fuel being pumped? I have to keep the nozzle about halfway out...any quick fixes?
thnx
Old May 20, 2006 | 08:53 PM
neurocity's Avatar
neurocity
Not quite my tempo
Most likely its a combination of the angle of the Fuel tank fill pipe and the automatic overflow shut off in the handle of the gas pump. If fuel goes in at a certain angle, then the overflow switch kills the pump.
Try holding the handle at a downward angle so the nozzle is more In line with the fill tube.
danmm7
GX - 1st Gen (2003-2009)
Nov 8, 2017 10:02 AM
b2884987
RX - 1st Gen (1999-2003)
Feb 2, 2017 12:33 PM
mstrsltr
19
Jan 23, 2017 11:55 AM
YWW
Aug 30, 2010 07:46 PM
fju2112
Jan 24, 2008 04:46 PM
