After Headgasket replacement: Engine burning coolant
Old May 4, 2006 | 05:11 AM
  #31
95 Integra's Avatar
95 Integra
Sorry to hear about the troubles, but in all honesty the 2JZs are pretty cheap if you just want to swap motors out. The block doesnt "generally" warp like the head because it is made from iron vs aluminum (higher melting point, malleable, etc) and has considerably more mass/strength. That and the head is exposed to the absolute hottest part of the engine (combustion chamber) and unlike a small gasket leak where a small % of the heat is getting to the block, the entire head is exposed to 1200+ degree temps. Now throw in the fact that since air raises to the top, the block generally still has coolant surrounding it while the head loses the coolant/cooling ability first. Thus, theres alot of reasons why the head warps and the block doesnt.....atleast when overheating is concerned.
BTW, where in TN are you (PM me if you dont want to post it all over the world).
Originally Posted by Inabj2
Water is the best heat transfering substance in the world.
Really now, because the metal in my pan heats up much quicker then the water within it. Also, if this holds to be true (for liquids I'll assume), then why use water wetter?
Old May 4, 2006 | 08:31 AM
  #32
TMaxxTim's Avatar
TMaxxTim
I'm in Nashville. I probably will end up swapping motors just because I don't want to deal with taking this one apart again. Hopefully I can get some help doing it and we'll be all set here in a few weeks.
Old May 4, 2006 | 09:20 AM
  #33
95 Integra's Avatar
95 Integra
BTW, after looking at your old pics (of the rebuild) a new motor is my suggestion as well. Mainly because your cylinder wall (#4) looked about like toast and your #1 cylinder clearly had coolant in it (due to the lack of carbon build up), yet it appears your head gasket was blown on something besides cylinder #1. Im sure if you wanted to do a total rebuild it'll be good to go....which isnt necessarily a bad idea either since a "used" motor might not be in much better shape.
Old May 4, 2006 | 09:36 AM
  #34
TMaxxTim's Avatar
TMaxxTim
II know that works. They aren't that expensive and the money I'd be paying to rebuild mine is far too much compared to just putting in a different motor.
I might keep the engine and see what I can do with it myself later, but for now it looks like I'll be finding a motor to swap it.
I see what you're saying with the cylinder walls and the no carbon in the first cylinder, I think that may have just looked funny from the way the picture was taken with the flash, because I remember that cylinder as dirty as the rest. Do you see where I took the picture of the headgasket?? What would casue that break in the copper ring then, could it have just fallen apart when I removed it if it wasnt from the blown HG?
Old May 4, 2006 | 10:06 AM
  #35
aliga's Avatar
aliga
Former Sponsor
i got a complete motor and tranny. 300 bucks. you cant beat that.
Old May 4, 2006 | 12:05 PM
  #36
TMaxxTim's Avatar
TMaxxTim
I'll let you know if I need that Algia. I really only need the engine, I want to keep my 5spd.
Old May 4, 2006 | 12:58 PM
  #37
laxdude362's Avatar
laxdude362
Hey man call me up soon 615-482-5423. I have a guy that I think still has a few salvaged sc's at his shop. He would prolly sell the 2jz cheap to you. He is the guy that is doing all the work for me.
Old May 4, 2006 | 01:05 PM
  #38
TMaxxTim's Avatar
TMaxxTim
Yeah, I definately will. I'm getting a Uhaul truck and trailer (the one that puts all 4 wheels off the ground), and driving to Louisville to go to the derby w/ my cousin then coming home on Saturday. Uhaul rents for 3 days at a time so I might as well make the most of it.
So I'll give you and Amir a call and we can work something out.
Old May 4, 2006 | 07:13 PM
  #39
95 Integra's Avatar
95 Integra
Get me a price....Ive been looking for a spare for awhile now....assuming its in TN somewhere.
Old May 4, 2006 | 09:43 PM
  #40
laxdude362's Avatar
laxdude362
Will do man.
Prajash
Sep 6, 2017 07:47 PM
ska0057
Dec 2, 2008 05:25 AM
habitat
Maintenance
15
Feb 11, 2007 11:42 PM
ozlx470
Oct 28, 2004 12:53 PM
