SC300 Strut Question
Old Apr 21, 2006 | 10:19 AM
Sobær's Avatar
Sobær
Default SC300 Strut Question
The shop I took my SC300 to said everything was in great condition, except there was some noise from the front end (suspension) that he thought might be the struts needing replaced. Of course, I want to replace the suspension eventually anyways, so would replacing the dampers fix the problem with the struts, or are they two seperate things? Any help would be extremly appreciated.
Old Apr 23, 2006 | 01:19 PM
SCoupe's Avatar
SCoupe
CL Folding 25,000
Did you take your SC in to the shop because of a noise you have heard? OEM struts don't make noise, Lower Control Arms do and that is an expensive fix. Use Search feature on "lower control arm" or "LCA"
Also, for gods sake, you can use less expensive and equally good Toyota MKIV Supra TT suspension components across the board, they all bolt up to the same mounts, SC and MKIV Supra separated at birth, remember that when it comes to many engine/drivetrain/suspension parts.
Old Apr 23, 2006 | 03:00 PM
TMaxxTim's Avatar
TMaxxTim
Yeah its probably your LCA's and not your struts, those dont seem to usually make noise on the SC. LCA's do though.
How new is your car? How many miles?
Old Apr 23, 2006 | 05:40 PM
T0ked's Avatar
T0ked
Please search and read carefully. The front MkIV Supra suspension parts fit, not the rear. Many parts are interchangeable, but search and read all the different exceptions.
Old Apr 25, 2006 | 10:34 AM
Sobær's Avatar
Sobær
I took the car to the shop just because I wanted everything checked out. Not because of the noise. It's not THAT noticeable. However, the other '92 SC I drove felt and sounded about the same, so perhaps either it was coincidently a bad part on both cars, or they both had the same problem.
The car I purchased was a '92. And it has 160k miles on it.
Old Apr 27, 2006 | 09:46 AM
SCoupe's Avatar
SCoupe
CL Folding 25,000
That's a much better way of putting it. Yeah, the rears are not the same, but the shocks, springs and sway bars (need subframe mts)come over.
Old Apr 27, 2006 | 10:24 AM
T0ked's Avatar
T0ked
By the time the SC reaches 100k miles or about 6-8 years old, I think the general consensus is that the LCAs are going out. I actually have the LCAs sitting in my home. Recently I began noticing that clicking when turning that seems to be indiciative of worn ball joints. My car has 102k miles and is 13 years oold now.
Old Apr 27, 2006 | 10:28 AM
T0ked's Avatar
T0ked
Also, remember that the LCAs can rarely be diagnosed correctly when everything is on the car. Usually the only way the bushings can be see clearly enough to be identified as the problem is once they are off the car. Take our word, I think there is enough evidence on the forums that at the age and mileage of your car, they should be replaced.
Old May 4, 2006 | 10:14 AM
Sobær's Avatar
Sobær
That being said..
Would it be more benificial to upgrade the LCA's (if there is such a way), or just go OEM?
mb12345
14
Aug 9, 2020 01:33 PM
rudy88
Maintenance
Jun 17, 2014 07:19 PM
Ludogg44
May 29, 2014 12:50 PM
cephas
Feb 13, 2012 01:27 PM
aparker813
Jun 2, 2009 11:01 AM
