1JZGTE MPG Q's
Originally Posted by VJ RC51
Since the 1JZ is in boost 90% of the time unless on the highway. Wow we dont even need an o2 sensor then right Mr. Toyota?
Just admit it, your statement about a bad O2 sensor was pulled out of your ***.
Originally Posted by kaosman
It doesn't matter. When in boost, you're not in closed loop, and the ECU is ignoring the O2 sensor. How hard is that to understand Mr. Ignorant? On a flat road, at 55 mph a 1JZ will not be in boost and will run off of the O2 sensor. When you accelerate, you may or may not be in boost...but this has nothing to do with how the ECU will react to different conditions. Not to mention an O2 sensor is needed for emissions...a catalytic converter operates at peak efficiency at stoich (14.7 afr).
I guess you personally never drove a 1JZ. Because i can easily make 5psi going 55mph in a straight line. I can make 5psi at 1600rpms. 10psi doing 85mph not even accerating. Its all how you work the pedal to work the wastegates and turbos. All this does not apply to my car anyways, it never see's closed loop. I average over 20mpg with a heavy foot.
Let me ask you something...do you really understand how a turbocharged engine works? Aside from "the blow dryer thingy blows air into the engine and you can make it sound badass with a blowoff valve"?
You're not getting 20 mpg around town boosting. End of story. Check your speedometer, its definately off.
Whoa, calm down guys. It was just a simple MPG question. Kaos, let me know when your free for that ride in the 1JZ. Send me a PM next time your available during the weekend.
As for VJ, this is the last thing I've got to say...
http://www.importmodifier.org/videos/1JZ.wmv
(Right-click and choose Save As)
khuezee
Mar 1, 2007 12:29 AM
