widest tire on 17x8.5" rim?
Looks like I might need new tires. I've got some Fittipaldis 17x8.5" w/ 235/45 SZ50s for my '92 SC300. What's the widest tire I can go with to fit my rims and stay within spec for overall factory diameter?
TIA!
TIA!
Well here's the deal, even though you have a 300, you can us a 400 size tire...the stock SC400 gets 225/55-16
A '92 SC300 came with 215/60-15...they're too small, which is why in '95, Lexus upped it to the same size as the SC400 (225/55-16)
So here's the break down in diameters...
215/60-15 = 25.1575" (Stock '92 SC300)
225/55-16 = 25.7441" (Stock '95+ SC300 and '92+ SC400)
Right there, the 16" is 2.28% larger...now for the 17...
245/45-17 = 25.6811
Compared to the 225/55-16, it's 0.25% smaller and compared to the 215/60-15, it's only 2.08% larger.
So you can see that even if you put on FACTORY '95 and up GS300 wheels, you'd be increasing the diameter MORE than doing the 245/45-17 setup...
Now if you go with the 255/45-17, you talking about a 26.0354" diameter...which is 3.49% more than the 215/60-15 and 1.131% more than the 225/55-16 tire...and you're 1.38% more than the 245/45-17...
Plus, a 245 fits a 8.5" wheel properly. 255's are designed for 9" wheels...
Hope that helps...
245/45-17 = 25.6811
Hope that helps...
thanx alot again!
I was under the impression I needed to stay within 1% of original factory diameter (25.175"). When Lexus upped the factory wheels to 225/55/16 did they make any adjustments to align the speedo?
I may just end up going 245/45/17. I'm actually afraid of loosiing what low end grunt my car has now by going w/ a larger overall diameter....
98supra6sp
SC- 1st Gen (1992-2000)
01-05-10 04:21 PM
