2jz-gte swap SC400 Project
I'm pretty savvy with wiring. Since the body plugs fit fine to the GTE harness Im guessing that the plugs have to be repinned? time consuming i bet...
Do you have a good resource of the GTE harness and ECU pin outs and one for the SC4 body plugs and ECU pin outs?
Im guessing it just moving around the pins to match up to the corralating body accessories.
I BEEN THINKING OF DOING THE SAME SWAP SO CAN U HELP ME OUT I NEED A PARTS LIST OF ALL THE THING I NEED TO DO THIS 1. SC300 MOUNTS power steering oil tank. 2.
seems like your af is also at about 13... kinda lean.
Get a usdm is worth the extra money. You get more aggressive cams and 550cc fuel injectors. But overall is the condition of the engine. I can't recommend my local place because I have to exchange with them 3 different engine until I find the one with the condition I wanted.
