Big Problem Soarer Swap help....
Old Mar 13, 2006 | 08:18 PM
lpolo69's Avatar
lpolo69
Default Big Problem Soarer Swap help....
Im currently doing the swap and the mounts wont line up....ITs a supra 1jzgte going into a soarer.?????? How come it doesnt line up......???? Please Help...
Old Mar 13, 2006 | 08:22 PM
ConSynX's Avatar
ConSynX
looks like a bracket issue because i believe the wrong mounts have their screws at an angle, while the sc and 97-98 supra is a straight line.
Old Mar 13, 2006 | 08:25 PM
lpolo69's Avatar
lpolo69
im using supra supra tt mounts and the car is a 92sc300......SO what are you saying use different brackets??And the mounts sit on an angle...
Old Mar 13, 2006 | 11:52 PM
5spdSC300's Avatar
5spdSC300
You have 2 options. Get supra motor mount brackets or lexus sc300 motor mounts. Make sure to specify the "short" brackets since they have 2 versions. NA supra mounts might be the same but i can't confirm.
I ran into this problem with my swap and opted for supra motor mount brackets since the supra mounts look a lot beefier.
~Kevin
Old Mar 14, 2006 | 07:11 AM
turbodude's Avatar
turbodude
when they say supra. lpc they mean mkiv supra not mk3.
Old Mar 14, 2006 | 07:27 AM
ConSynX's Avatar
ConSynX
if i got it right, it's supra mkiv mounts from 95.4-98
both NA and turbo supras used same mounts(guess since don't seen different part #'s on supra forums)
they're 3.5" tall, while the 93-95.4 is ~5"
the part number for the 97-98 is 12360-46111
i just ordered a pair, they're about $110 for both.
i'll let ya know if mine work if you want to wait.
Old Mar 14, 2006 | 11:08 AM
lpolo69's Avatar
lpolo69
supra na and supra tt have the same mounts.......ITs the Bracket that different........I think ima try to use the sc300 bracket to see if it makes a difference..ill keep u guys posted...DO you know if i can use the Sc300ge Brackets with the mkiv mount?
Old Mar 14, 2006 | 11:59 AM
VJ RC51's Avatar
VJ RC51
those are NOT soarer motor mounts that for sure.
Old Mar 14, 2006 | 01:18 PM
lpolo69's Avatar
lpolo69
yeah i know......another question..........the 1jz supra had the sump in the front....Is the soarer rear....If so does this mean i have to swap oil pans?COuld this be my problem>??Im using mkit tt mounts....Their alot more beefier....
Old Mar 14, 2006 | 02:11 PM
BLK13X's Avatar
BLK13X
For Mind Cruising
The 1JZ from a JZA70 is different to the one out of a JZZ30. The sump is different, I'm sure there are people that have swapped their oil sumps for the right ones but don't hold me to that.
Old Mar 14, 2006 | 03:04 PM
got_trd's Avatar
got_trd
should have stuck with a soarer engine set... im pretty sure thats why you are having problems with your harness as well
Old Mar 14, 2006 | 07:11 PM
lpolo69's Avatar
lpolo69
I swapped the oil sump today and the pan......Im gonna shift the bracket location over and see if that solves my problem,..
Old Mar 14, 2006 | 07:13 PM
VJ RC51's Avatar
VJ RC51
What chino said. With a soarer set, its drop in, plug up, turn key and drive.
Old Mar 14, 2006 | 08:54 PM
lpolo69's Avatar
lpolo69
well not much i can do...thats the hand i was delt with,...
Old Mar 14, 2006 | 09:03 PM
STRONG SC's Avatar
STRONG SC
Damn, great heads up! How does one know if it's a soarer set or supra set by physically looking at it?
