Rear Strut Tower Bar
Old Feb 27, 2006 | 07:43 PM
neurocity's Avatar
neurocity
Not quite my tempo
Default Rear Strut Tower Bar
I'm going to make a Rear Strut Tower bar. I think a may have to remove the sub woofer, but I think It can be done with the right geometry. Mines a 97' so i'm not sure if the years prior are different in that area.
The strut brackets are going to be the hardest to fabricate, the bar itself should be easy. I'm just going to do aluminium for now....
Any sugestions or ideas are more than welcome.
Drawing up some plans right now.
Old Feb 27, 2006 | 07:49 PM
SWSC400's Avatar
SWSC400
Cool man, go for it! keep us posted....
Old Mar 2, 2006 | 05:49 AM
neurocity's Avatar
neurocity
Not quite my tempo
!!!Up Date!!!!
Anyone know were I can get parts for strut tower bars. I've decided instead of making my own strut-bracket, I'm going to modify one that matches the bolt pattern. Then add my own bar.
Are there any universal build your own kits???
Thanks
Old Mar 2, 2006 | 06:42 AM
xirforever's Avatar
xirforever
Your best bet is to take the braket to a machine shop and have them make the new ones you want
Old Mar 2, 2006 | 08:30 AM
vipsoarer's Avatar
vipsoarer
or you could just use some .5" sheet metal and drill it out what you need and then use an angle grinder to take off the larger stuff. your going to run into clearance problems with the gas tank being directly in the way hence why there arent any on the market. another thing is that the rear tub of the sc is incredibly rigid. I would hold off and get a cage if you want the body to be stiffer.... just an experienced opinion
Old Mar 2, 2006 | 09:33 AM
DriftGirl's Avatar
DriftGirl
It does NOTHING for the chassis in these cars ....Ive had one for a while. I did it just to be doing it' because noone had it.....waste of time/money if you're into performance. The rear is the stiffest part of our chassis. I didnt notice any change
But If you're doing it for 'show' or just for the thrill of fabricating parts....cool.
Old Mar 2, 2006 | 04:17 PM
neurocity's Avatar
neurocity
Not quite my tempo
It does NOTHING for the chassis in these cars ....Ive had one for a while. I did it just to be doing it' because no one had it.....waste of time/money if you're into performance. The rear is the stiffest part of our chassis. I didn't notice any change
or you could just use some .5" sheet metal and drill it out what you need and then use an angle grinder to take off the larger stuff. your going to run into clearance problems with the gas tank being directly in the way hence why there aren't any on the market. another thing is that the rear tub of the sc is incredibly rigid. I would hold off and get a cage if you want the body to be stiffer.... just an experienced opinion
That's what I needed to know, makes sense why there are none out there now.
So kinda pointless....very good
Thanks guys!!!
Old Mar 5, 2006 | 09:03 PM
SC400TT's Avatar
SC400TT
Does anyone know if there is a front mount STB that clears the motors of the TEIN EDFC?
Thanks,
Ryan
Old Mar 6, 2006 | 05:47 AM
neurocity's Avatar
neurocity
Not quite my tempo
The brackets for the Luxury Mods STB seem tall.....
Old Mar 6, 2006 | 09:41 AM
LexAnt's Avatar
LexAnt
Thanks,
Ryan
TRD STB for Supra TT works wit lil mods, just had to grind a lil under the bar, where the motor would be, dats wat i did
Old Mar 6, 2006 | 11:40 AM
Luv Da Lex's Avatar
Luv Da Lex
if the rears are worthless because it wont really change anything, how about the fronts? i want the TRD STB, its just so sexy compared to cusco.
Old Mar 21, 2006 | 12:58 AM
vipsoarer's Avatar
vipsoarer
floor bars are redundant. They add strength where it doesnt need it and are mostly for show. B pilar braces, also known as "harness bars" do more than a floor bar, atleast on the SC.
Old Mar 21, 2006 | 02:29 PM
ACleanSC4's Avatar
ACleanSC4
Thanks,
Ryan
Carbing bars...
Old Mar 21, 2006 | 05:18 PM
rscott's Avatar
rscott
Originally Posted by ~SC~
i've heard a floor bar will replace the rear strut bar, plus roll cage.
yeah not too many people are too much into the roll cage idea though...but for those who are, the cage will add more rigidity than any type of strut bar as long as its made right and not just bars welded to random spots.
midwest2
17
Sep 30, 2011 02:16 PM
DarKnight
Suspension and Brakes
Sep 23, 2006 07:33 PM
cupete
Dec 23, 2001 12:19 AM
