supra ground controls?
Old Feb 24, 2006 | 02:38 AM
jdmtruong's Avatar
jdmtruong
Default supra ground controls?
since supra na/tt suspensions fit on our cars, wouldnt u think ground control coilovers will fit also? i been searchin around but i cant find anyone or anyone saying anything bout fitting it on. i mean, the stock suspension fits on, i believe the coilovers should too right? im on a budget roll so i pretty much ground control is my best budget suspension.
Old Feb 24, 2006 | 07:37 AM
kietlander's Avatar
kietlander
ground control with KYB AGX??? or GC on stock shocks???
Old Feb 24, 2006 | 12:01 PM
JspecSC3's Avatar
JspecSC3
Here is a bit of info I found..
1994-1998 Toyota, Supra (All Trims)
Notes: shocks: 4, 5, 10 only
Notes: F
4. Koni
5. Bilstein
10. GAB HP
NOTE F: includes new upper mounts and must be used with machined aftermarket struts specified
Old Feb 24, 2006 | 12:21 PM
JspecSC3's Avatar
JspecSC3
Hey Troung, if the Supra suspension does fit the SC with no problem you might want to consider getting these bad boys..
They are the Tein Basic coilovers. They come with the adjustable shock. For about $100 more than the GroundControls you can pick those up. Its a better value buy in my opinion.
http://www.horsepowerfreaks.com/pric...ers/part/Basic
Old Mar 1, 2006 | 07:20 PM
BMwhat?'s Avatar
BMwhat?
so do you know how many inches the basics will drop an SC..... ?
Old Mar 1, 2006 | 08:27 PM
Cannonbear's Avatar
Cannonbear
i believe the lowest it'll drop a car (tein basic coilover set) is 2.2 front 1.5 rear (according to their website if i'm reading it right.
http://www.tein.com/badamp.html
Old Mar 7, 2006 | 05:10 PM
pcmw's Avatar
pcmw
Be sure that the ground control psuedo coilover spring setup you get is under tension when the strut is fully extended. Otherwise it will unseat or scratch up the pistons in the strut causes catastrphic failure to your entire suspension costing you WAY more than what you saved.
Old Mar 8, 2006 | 07:28 PM
J J's Avatar
J J
Get the teins if you are on a budget, it is cheaper than ground control coilovers + new shocks.
If you are not on tight budget (<$1200) I'd pick ground control over teins any day, and so would 99% of competetive racers.
Old Mar 9, 2006 | 06:41 PM
CantSeeMe's Avatar
CantSeeMe
Dont forget that MKIV suspension setups should lower an SC an addl. .7'' .
Old Mar 9, 2006 | 09:17 PM
JspecSC3's Avatar
JspecSC3
Does this also apply to the MKIV Coilovers from a Supra?
BostonSC4
Nov 4, 2009 11:56 AM
Lex-Fiend
Dec 22, 2007 01:50 PM
PandaAE86
May 7, 2006 01:13 PM
cefiro
Feb 23, 2004 12:29 AM
ChronoJ1
SC400 / 300 Classifieds
Jan 21, 2003 04:55 PM
