Help choosing grounding kit
Old Feb 21, 2007 | 06:19 PM
itssr20's Avatar
itssr20
Originally Posted by STRONG SC
I've got a grounding kit from Hyper. Does the job, spend the money to save time or do it yourself.
After getting a $100 grounding kit, could you tell any difference performance wise? I did a DIY grounding kit on my turbo powered 240sx few years ago - but the only thing I really noticed was brighter lights.
I'm thinkin bout doing the stereo shop power wire method on my SC4, and just wanted to see what you guys are gainin out of this.
Old Feb 21, 2007 | 09:11 PM
itssr20's Avatar
itssr20
found this on the web. Its an article using ground kit boasting an increase of 14hp over stock on the dyno...but I'm not sure if I should believe it
http://www.caraudiomag.com/testrepor...ground_system/
What you guys think?
Old Feb 21, 2007 | 09:31 PM
TeCKis300's Avatar
TeCKis300
PM me with your email and I will forward you the Teck Grounding Kit Instructions.
Old Feb 28, 2007 | 02:00 PM
itssr20's Avatar
itssr20
For anybody wantin to DIY Ground kit, just go to your local welding supply store and get some #4 or larger welding cable, and some battery connectors from an auto store. Cheapest way to do it.
Old Mar 9, 2007 | 04:56 PM
over40driv's Avatar
over40driv
I never got my e-mail returned.
Old Mar 9, 2007 | 06:07 PM
TeCKis300's Avatar
TeCKis300
Are you asking me? I never got a PM with your email addy.
Old Mar 9, 2007 | 06:37 PM
over40driv's Avatar
over40driv
Whose addy, anyway I e-mailed some company about price and availability of their ground kit.Never got a reply.
Old Mar 13, 2007 | 06:29 PM
Sc dRifta's Avatar
Sc dRifta
*****Do not buy from this member until further notice *****
i got 4 gauge wire for 2.50/ft just to let you know how much it cost i ended up going with -0/2 gauge ahah das right do it once do it right.
btw i run 2 capacitors as well
4 tv's
1 dvd player
1 amp
1 head unit
1 gps
1 power outlet for my blender i like drinkin smoothies when i drift
Old Mar 14, 2007 | 08:32 AM
RedPhoenix's Avatar
RedPhoenix
im going to make my own. lots of 8 awg, get some terminals on ebay or something. however what are you guys using to connect all the ground wires together? i was thinking of taking a copper slab and drilling it and tapping it for bolt holes.
Old Mar 14, 2007 | 12:31 PM
itssr20's Avatar
itssr20
I used #4 welding cable from Airgas and battery cable connectors from autozone.
Alt to body(passenger side where stock ground is)
battery to body(near driver shock tower)
battery to block
block to body(firewall)
intake mani to firewall
throttle body to firewall
I still need to do one either from passenger block to body, just been lazy.
Old Mar 14, 2007 | 10:42 PM
BLovesc's Avatar
BLovesc
Get Buddy Club because i work there
Old Mar 15, 2007 | 06:54 AM
DryBlaze's Avatar
DryBlaze
Why don't you hook us up with a good price for it then.
Old Mar 15, 2007 | 08:08 AM
slammedTT's Avatar
slammedTT
I bought a buddyclub one for my Integra Type R and didn't notice anything, this should be the absolute last mod you do to your car if you do it at all.
Old Mar 22, 2007 | 05:26 PM
over40driv's Avatar
over40driv
I want to buy a ground kit and would like to know which one is the best.
Old Mar 22, 2007 | 09:48 PM
TeCKis300's Avatar
TeCKis300
It's like anything, no point upgrading to stage 4 clutch when you're only putting down stock power.
Tell that to the guys that have huge audio systems and added electronics? They should just run stock 16 gauge wiring in that case. Ever heard of the big 3 mod for audio systems? The ground is a huge part of it IF you are modding your stereo/electronics because the stock ground is only sized appropriately, just like your clutch, your alternator, your power wire.
Also, look around at people who use standalones. There are proven logs to show cleaner and more consistent sensor readings and pickups. There are examples of ECU's picking up crank/cam angle readings inconsistently and bam...with a grounding kit, it fixes their problem.
But if you don't have aftermarket stereo's or electronics, then yes, it probably shouldn't be a priority. But the IS boards have consistently felt better and more consistent shifting with the addition of a grounding kit, even stock.
