Bushing options and part numbers
Old Feb 1, 2006 | 09:48 AM
TeCKis300's Avatar
TeCKis300
Default Bushing options and part numbers
My '98 SC300 currently has 100k miles and I am looking to refresh most of the suspension. I have been doing a lot of researching on the site but would like help consolidating some information as I couldn't find every part number I needed.
My goal is to refresh the suspension back to it's original form so urethane bushing are out of the question.
I am still missing a bunch of information so if you guys could help fill in, I'll edit my post to consolidate the information.
FRONT SUSPENSION
Lexus LCA forward bushing (1 per side): #48654-24040 ~$30
Lexus LCA rear bushing (1 per side): #48655-24050 ~$40
Lexus complete LCA assembly: #48069-29215 ~$510
Lexus complete UCA: ~$150
Options:
1) Vlamos LCA bushing set $330
2) Lexus complete LCA w/bushing and ball joint: # ? ~$450/each
3) Supra complete LCA w/bushing and ball joint: #? ~$210/each
REAR SUSPENSION
Lexus LCA bushing: ??? (Are these even offered?)
Lexus UCA bushing: ??? (Are these even offered?)
Lexus LCA: #48069-29165
Options:
1) Vlamos rear bushing set (LCA & UCA)
DRIVETRAIN
Lexus Engine mounts(2): #? ~$110
Lexus Transmission mount: #? ~$55
Options:
Toyota 2JZ-GE Engine mounts(2): # ~$55/each
STEERING RACK
Lexus Passenger side Steering Rack Bushing: #45517-24030 ~$13
Lexus Driver side Steering Rack Bushing: Not available
Options:
1) Vlamos steering rack bushing set ~$55
SWAY BAR
Lexus Front Sway Bar Bushings: #48815-24051 ~$13/each
Lexus Front End Links: #48020-24010 ~$70/each
Lexus Rear Sway Bar Bushings: #? ~$12/each
Lexus Rear End Links: #48030-24010 ~$40/each
Options:
Vlamos bushing prices:
Cost of the 4 front lower control arm bushes $330.00
Cost of the 4 front upper control arm bushes $270.00
Cost of the 4 rear upper control arm bushes $270.00
Cost of the 4 rear lower control arm bushes $270.00
Cost of the 2 steering rack bushes $55.00
Shipping for the complete set AUD $78.50
Shipping for one set only AUD $38.50
You can convert the currency http://www.xe.com/ucc/ and pay in US dollars via Pay Pal or pay in Aussie dollars ....your choice.
View range www.vftbushes.com
Old Feb 1, 2006 | 12:11 PM
mikeloc24's Avatar
mikeloc24
call any Lexus dealer and ask for the parts counter. They'll give you all the part numbers you want.
Old Feb 1, 2006 | 12:39 PM
Project300's Avatar
Project300
Since you are looking to keep the stock ride and feel, parts will be easy to find.
I have all the part numbers you need, so I'll post them later.
Looks like you have a pretty good list going there. You will have a new car after all these bushings and mounts are replaced. I know Lexus carries the sway bar bushings for about $12 each and I paid $70 each for my Lexus end-links.
The steering rack mount for the passenger side is available thru Lexus for about $13. However, the dirvers side rack mounts are only available thru eBay for about $45 or Vlamos for about $70.
More to come...
Old Feb 1, 2006 | 01:40 PM
TeCKis300's Avatar
TeCKis300
Project300...looking forward to your post. I'm still debating whether to change all bushings wholesale or just pick and choose the ones I need. Definitely doing the LCA bushings at this point but it would be still nice to have a consilidated post of all parts, numbers, and prices.
Are the front and rear sway bar endlinks the same? Is the toyota part equivalent?
Old Feb 1, 2006 | 02:48 PM
mikeloc24's Avatar
mikeloc24
I just purchased and installed a set of rear sway bar endlinks on my SC300. Cost $40.75 each from Carson Toyota. I bought the accompanying nuts as well (4) which cost an additional $3.32, not a big deal.
Lexus rear sway bar endlink part #48830-24010
Being as I've gone through the process of dealing with lca bushings, read threads upon threads about poly vs. OEM bushings, checked to see how much shops charge to torch out and press in new bushings, etc...I am now a firm believer in just avoiding the entire situation and going straight to Supra lca's. This IMO is the more cost effective route to take and it addresses several issues while only spending a single amount on installation.
I'll elaborate if necessary.
Old Feb 1, 2006 | 11:31 PM
sdastg1's Avatar
sdastg1
This is an exellent post. I just want to restore the stock ride. I need all this info. in one place as well.
maybe once we have it all together, we could get carson to do a group buy on them, and save a few more dollars.
Old Feb 2, 2006 | 10:34 AM
mikeloc24's Avatar
mikeloc24
I tried that bro, it's not worth it. It will save you like an additional $2 at most and you'd have to wait for the GB to end before your parts are ordered/shipped out. Buying them straight out from Carson is about as inexpensive as it gets
Old Feb 2, 2006 | 01:44 PM
Project300's Avatar
Project300
Post Here is the first part
Originally Posted by TeCKis300
FRONT SUSPENSION
Options:
1) Vlamos bushing set (LCA & UCA)
2) Lexus whole LCA w/bushing and ball joint: # ? ~$450/each
3) Supra whole LCA w/bushing and ball joint: #? ~$210/each
Like mikeloc said, go with the Supra front LCA's from Carson Toyota. They have slighly stiffer bushings. It's a no-brainer unless you really want to spend the extra cash for Lexus arms for a truly stock ride, which is where Vlamos is good. Last I checked, Lexus didn't even carry their bushings separate from the arms, but your part numbers are correct on the bushings.
Front Upper Control Arm (L) 48630-29046
Front Upper Control Arm (R) 48610-29046
All of the shaded parts were replaced when I did my rebuild plus the arm itself.
More later.....
Old Feb 2, 2006 | 01:51 PM
mikeloc24's Avatar
mikeloc24
That rear bushing (#48655-24050) is normally the first one to go. If your suspension is suffering then it's a good bet that particular bushing is shot on both sides. If you're poor at the moment, replace those 2 bushings alone and your ride will improve dramatically...but if you can muster a bit more spring for the Supra arms and just be done with it.
Old Feb 3, 2006 | 12:02 PM
Project300's Avatar
Project300
SWAY BAR
Lexus Sway Bar Bushings: ??? (Are these even offered?)
Lexus End Links: #? ~$110/each
Options:
The front sway bar bushings are available from Lexus for bout $13 each. They are really easy to install too. The front end links are about $70 each from Lexus. Not sure about the rear ones.
Old Feb 3, 2006 | 12:20 PM
Project300's Avatar
Project300
STEERING RACK
Lexus Steering Rack Bushings: ??? (Are these even offered?)
Options:
1) Vlamos steering rack bushing set ~$315
Only the passenger side steering rack bushing is offered from Lexus for about $15. The driver's side ones can be found on eBay.
I used the Vlamos bushings for the driver's side because they weren't available anywhere else at the time and I paid $70(US) shipped.
Old Feb 5, 2006 | 07:22 AM
TTurboPimp's Avatar
TTurboPimp
This is a good thread, just saved me some search time........
so if im reading this correctly, the Supra lower control arm is a direct bolt on replacement on the SC? Any difference between the SC300 and SC400? I wouldnt think so, but just checking.
Would it be the Supra TT or Supra N/A control arm? And why not go with a new SC control arm, are the Supra ones that much less $$$$....and how much are they?
I take it the Supra Upper Contorl Arm isnt a direct repalcement?
I will search in the meantime............
Old Feb 5, 2006 | 07:32 AM
vipsoarer's Avatar
vipsoarer
supra control arms are a direct replacement. there arent any differences between the 400 and 300. you can use either control arms from the supra but i think its the tt that has stiffer bushings (it may be both, someone else can chime in on that) they supra control arms are about half the price of lexus control arms with a stronger bushing from carson toyota. ($300 vs. $600). the stock lexus upper arms are like $150 new so u might as well get those since they arent expensive but the supra ones should work too.
Old Feb 5, 2006 | 07:41 AM
TTurboPimp's Avatar
TTurboPimp
Thanks for the response.....I actually found most of my answers in the last 5 minutes of searching.....Ive been around long emough to know better than to ask before searching!
Old Feb 6, 2006 | 02:11 PM
TeCKis300's Avatar
TeCKis300
Thanks for all the input guys. I think I've captured most of the information here.
As for my situation...I've gotten under the car and really looked at the busings. The front LCA bushings are visibly worn whereas all the others look pretty well intact. I've already recieved new front Lexus LCA bushings and will try installing them this week. Will let you guys know how it turns out.
