Cant Start SC with clutch!
Originally Posted by 95 Integra
Is the starter hooked up correctly? If so, its probably the wiring to the ecu that says the clutch is in.
I dont quite understand that part.
Originally Posted by SC3002JZ-T
So....did you ever get your car started?? If so what wires did you have to jump or connect....I'm on the sameboat....Any help would be appreciated...Thanks
What you do is you look for the big one that is not plugged in. You turn the key to the "ON" position just so there is power running to the car. You then get a power tester and start testing for power on that plug. You poke each hole on the plug. If your tester lights up then you have power! There is supposed to be two holes that are supposed to be making your tester light up. What I did was I spliced wires with another wire running to the center console up onto the push start button. You do that to both of the wires on the plug that made your tester light turn on. When tapping those two wires together while having your car key in the "ON" position you will be able to get it started with no problem. Goodluck
I really really realllyyyy want to use the clutch to start my car!
Originally Posted by prjctSC300
cant you just wire the clutch switch wires to the wires your jumping??
I know there has to be tons of successful 5speed conversions on the SC from members of this forum. If any of you are reading this please help me out. Ive been stuck for a good while now.
Just a little update..
I completely took off all of the panels and stuff that are located underneath the steering wheel. All the wiring and pedals were exposed. Someone had suggested that I check up the MKIV.com site again. They say the plug for the clutch sensor is located right near the clutch area. I took my time searching for it today and no luck. Is there a way where I can just rigg it to the harness somehow? 5speed conversion guys can you help me out?
BlueKush86
Aug 8, 2006 06:21 PM
