Leaking Oil Pan Gasket
Old Dec 31, 2005 | 01:41 PM
GOLDSc300's Avatar
GOLDSc300
Default Leaking Oil Pan Gasket
Hey guys,
Nice to be back. I've been super busy and haven't posted anything in close to a year. Now I have a few problems. My 92 SC300 seems to be leaking from two places. From the oil pan and from the spot that the engine connects to the transmission. Any suggestions on what to do? Are these leaks something I can fix myself or do I need someone to do it for me. If so whats the average cost for these repairs?
Old Dec 31, 2005 | 02:11 PM
xknowonex's Avatar
xknowonex
One of them sounds like its the rear main seal.
Old Dec 31, 2005 | 05:29 PM
5spdSC300's Avatar
5spdSC300
I'd agree. Does sound like the rear main seal.
Old Jan 1, 2006 | 11:34 AM
rscott's Avatar
rscott
rear main seal = drop the tranny
oil pan = drop the oil pan some and scrape off all the old gasket with not so much working space
both are definitely not my favorite jobs.
Old Jan 1, 2006 | 11:40 PM
xknowonex's Avatar
xknowonex
Luckily both my front main and rear main seals are pretty dry even at 144k miles. However, if mine are leaking, I would probably consider swapping a 1jz if smogging isnt a concern since the costs are pretty high
Old Jan 2, 2006 | 06:14 AM
Psionic's Avatar
Psionic
http://auto-rx.com/pages/sealleak.htm
Old Jan 2, 2006 | 11:46 AM
xknowonex's Avatar
xknowonex
Originally Posted by Psionic
"Important Note: Auto-Rx® will not correct mechanical defects or damaged components. If you suspect damaged or torn seals, Auto-Rx® will not be able to restore them and stop the leakage."
Old Jan 3, 2006 | 03:28 PM
Psionic's Avatar
Psionic
The seal might not be torn... I would at least try it before dropping the transmission. I'm cheap like that though
Old Jan 3, 2006 | 10:11 PM
shaman's Avatar
shaman
Best it will do is stop the leak by cleaning you engine and the seal so that it can seal, the worst it will do is clean your engine and open up the leak more.
2006fxdc
Apr 3, 2017 09:08 AM
Bocatrip
Mar 15, 2017 11:40 AM
kuziwk
15
Apr 21, 2015 05:37 PM
jayr0422
Nov 29, 2009 04:43 PM
djspawn00
Sep 26, 2009 08:39 AM
