soarer brake question
Old Dec 30, 2005 | 09:41 PM
sc1jzgte's Avatar
sc1jzgte
Default soarer brake question
well im getting my soarertt front half in next month right after i get back from iraq and ive read the jzz30 (soarertt) has bigger brakes than my sc300 jzz31. so i was thinking of swappin my front brakes with them, but i was wondering if anyone can confirm and help with a few things concerning the soarertt front brakes..
1)i read that they are 2pot like the sc300, but they are just a little bit bigger, not 4pot like the supratt and the ls400
2)so if thats the case what kind of rotors and brake pads do i get for them, like is there a US equivalent, mayby they are the same as the sc400 brakes?
im basically trying to buy some rotors and pads for the soarer front brakes and need to know if i can look under a different car application that will fit.
thanks, bryan
and btw, i know its a cheap way to go but has anyone had experience with or knowledge of those steel brake lines on ebay, magnum brand i think
Old Dec 30, 2005 | 10:16 PM
iasc300's Avatar
iasc300
welcome back from iraq i was there 14 months feb.03 - apr. 04 so welcome home-
Old May 19, 2006 | 10:37 AM
sc1jzgte's Avatar
sc1jzgte
bump......... ...
Old May 19, 2006 | 11:00 AM
Lexiss_sc430's Avatar
Lexiss_sc430
The only thing I can think of is that they probably use the SC400 brakes in the TT's over there....
Your 300 has smaller/weaker brakes then the stock 400's I believe...
So the clip you bought is most likely coming with a sc4 calipers... there will be an increase in your stopping distance but not by much.. if your going to be boosted you need something like a LS4 or Supra TT upgrade, the SC4 brakes are also pretty inadequate for our cars...
-Tommy
Old May 22, 2006 | 11:03 AM
Notorious's Avatar
Notorious
I've read that the brakes used in the 1JZ Soarers are the same size as our USDM SC400 brakes (which are indeed a little larger than the SC300 units).
I just ordered rotors and pads (in the SC400 size) for my car, which has front Soarer brakes. I'll let you know if they work or not... I plan to do the brake job over the weekend.
FredyGutz
Apr 30, 2017 05:25 PM
TSleid
Apr 12, 2012 08:08 AM
Shanty
Feb 5, 2010 08:53 AM
drewdizzle
Mar 8, 2009 12:50 PM
