my trac light is on
Old Dec 30, 2005 | 01:24 AM
hisc400's Avatar
hisc400
Default my trac light is on
ok i have 95 sc 400 lexus , my trac control light is on but i cant turn off, it alway on , i check the fuse and it good, need help please
Old Jan 2, 2006 | 09:29 AM
rdm20fan's Avatar
rdm20fan
Is your Check engine light also on?
If it is, the ECU turns "OFF" the traction control.
Fix the check engine light, and the traction control works again.
Old Jan 2, 2006 | 10:18 AM
Project300's Avatar
Project300
When the TRAC light in the middle of the tach stays on it means the system is not functioning. Somewhere a component or sensor is making the light stay on. When I had this problem, it was because one of the electric control harnesses on the throttle body was loose. After I checked and reconnected the harnesses it worked great. Hope yours is as simple a fix too.
If your ABS system is not working, your TRAC will not work either.
Old Jan 2, 2006 | 11:51 AM
Koma's Avatar
Koma
CL Folding 25,000
I know this is a dumb question but did you press the TRAC-off button?
Old Feb 23, 2006 | 09:41 AM
Jewcano's Avatar
Jewcano
No Sir, I Don't Like It
CL Folding 1,000,000
Well if you have a prob like i did, when the TRAC light just showed up and your TCS didnt work. All i did was mess with the Hoses under the hood, that linked the TCS to the throttlebody, and stuff like that. (IE I made them tighter over the fittings). And boom, it works good as new.
Turns out that method didnt work, anyone else have another idea??
Old Mar 15, 2006 | 01:18 PM
southtrian's Avatar
southtrian
how did you solve the problem ,does the system computer store codes I tried to disconect the battery cables that did not work, 1993sc300 in factory trim no upgrades
Old Mar 15, 2006 | 01:41 PM
Bagadonutz's Avatar
Bagadonutz
I am having this problem also. It started right after I did a tuneup making me think I left something loose. My TRAC light will stay on all the time save 3 early morning cold starts. I have now quadruple checked that all the connectors, hoses, etc. are tight. My next step is to use a volt meter to test the TBS plug connector and wires to make sure no old wires broke. I have to admit, that connector got pushed and pulled on a lot when removing it to take off the intake pipe with the resonator on it. Anyone else have any other trouble shooting suggestions?
Old May 14, 2006 | 08:09 AM
Paul_Cos's Avatar
Paul_Cos
Default TRAC lite on
I am having the same problem...have had this problem for 3 years and no one has a sollution. TRAC lite goes on after startup. No Check engine lite. I disconnected the TRAC computer for several months, then reconnected and it didn't act up for about a year. Then, back again. Excessive pumping is the error code. Anyone have a permanent fix? Car is stock, 95 SC300 142,000 miles, and bought it new.
I have disconnected the battery for 48 hours and that sometimes removes the problem for a day or so. When I start up, before the error shuts off the TCS, if I spin the wheels which kicks in the system, that sometimes helps for a trip or two. Then back again. Wish I knew the answer. It has spoiled the pleasure of owning this wonderful car.
Old May 14, 2006 | 08:52 AM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
try here:
https://www.clublexus.com/forums/sho...ght=trac+codes
or search "trac code" - 14 threads. Please post back w/ Q's or if you find the resolution.
(nothing worse than searching & finding posts w/ no answers.)
Old Jul 6, 2006 | 03:37 PM
dxb625's Avatar
dxb625
I had the same problem in '04.. took it to the dealer and they said it was the O2 sensors. fixed those and ran good till now, the TRAC lights are back on again. I also noticed my gas mileage has been horrible lately.. around 17mpg on the highway for a GS300. I changed the air filter lately, hardly ever use the A/C, and keeps my tires inflated all the time.... suspect the poor mileage is linked to the TRAC problem.
detsc400
May 23, 2019 10:02 AM
mechanChic
Oct 17, 2012 10:32 PM
Crown
Mar 5, 2012 02:36 PM
dandd2
Nov 26, 2005 04:14 PM
jcart05
Jun 16, 2004 09:35 AM
