My 1JZ swap.
Old Dec 11, 2005 | 03:39 PM
Aristo300's Avatar
Aristo300
Default My 1JZ swap.
Well the motor came last Wednesday from JHOT. I started on the wiring yesterday lengthening the harness.... it's looking like a mess, but hopefully when it's done it all extends out and doesn't tangle up. Here are some pictures.... I'm basically opening this thread just for troubleshoot purposes and the pictures that people may be interested in seeing.
1JZ from JHOT still on the crate.
Wiring extension to the harness started.
Soarer fuel pump - does anyone know if this thing is worth putting in?
2JZ-GE engine harness pulled through the firewall, very simple.
Motor is loose, ready to come out.
Old Dec 11, 2005 | 03:40 PM
Aristo300's Avatar
Aristo300
We had some trouble with a few clips, connectors, etc that were on the lower portion of the engine. We finally got everything out... then we forget the linkage on the transmission. After it was completely loose we tugged forward on the motor hoist a few times and the driveshaft fell out. The motor was out in about 2.5 hours.
On the way out.
Pretty much out. I had to guide it a little so it didn't bang the car up.
Airborn.
Empty engine bay.
Looks like it's time to put something in there.
Old Dec 11, 2005 | 03:58 PM
Psionic's Avatar
Psionic
Good job so far .
Old Dec 11, 2005 | 04:45 PM
Rising_Sun's Avatar
Rising_Sun
Wow...Looks great! Good luck with the swap!!!
Old Dec 11, 2005 | 04:52 PM
LexusFTW's Avatar
LexusFTW
Great Progress so far. Keep it up!!
Old Dec 11, 2005 | 05:06 PM
Aristo300's Avatar
Aristo300
A few first questions after looking over the car and the 1JZ.
[1] This is the part # I ordered for the throttle cable: 78180-1b090 Cable Tt 2j Models Mkiv List 57.36 Cost 42.41
I hope this is the right one. I've seen where it was mentioned in another 1JZ thread that it was too short, but others have had no problems. Can someone expand on this?
Does the cable have to be attached behind the dash near the throttle pedal and then pulled through the firewall?
[2] The knock sensors. Did you remove the complete wire and run a new lengthened one? Or did you splice into it where the wires go into the main harness bundle? Also where did you get your shielded USB cable?
[3] The power steering resevoir. What setup did you use? I was thinking about taking my stocker and mounting it in a different location and running new lines.
[4] We can't figure out where the heater hoses attach on the 1JZ. Any help?
Old Dec 11, 2005 | 06:01 PM
SoarerJzz3's Avatar
SoarerJzz3
Lookin good
Old Dec 11, 2005 | 06:41 PM
Last5Spd's Avatar
Last5Spd
as far as i know.. i was told that you need to flip the bracket to use the TT throttle cable. and yes thats the correct part number. same one i bought...
Old Dec 11, 2005 | 07:11 PM
Kaiser's Avatar
Kaiser
I'm still using my SC300 fuel pump with stock boost. It was plenty rich on the dyno.
Old Dec 11, 2005 | 07:15 PM
Rising_Sun's Avatar
Rising_Sun
[QUOTE=BrownDuckz]
[4] We can't figure out where the heater hoses attach on the 1JZ. Any help?[/QUOTE]
The inlet Heater hose that connects to the control valve comes off the pipe behind the rear turbo and the outlet hose connects to the opposite side of the engine block. Please disconnect the outlet heater core hose while the engine is out, its a PITA when the motor is in.
Old Dec 11, 2005 | 08:45 PM
AURELIOMK3's Avatar
AURELIOMK3
hey chris its me aurelio the guy that called you about the motor anyways, hope everything goes well and its looking good and thanks for everything if you know what ia mean lol
Old Dec 11, 2005 | 08:58 PM
Aristo300's Avatar
Aristo300
Did you get in touch with Jonathan@JHOT? When will your motor arrive?
Old Dec 11, 2005 | 09:14 PM
AURELIOMK3's Avatar
AURELIOMK3
ya sure did, paid for shipping on thursday just want to thank you man ,if it wasn't for you and scott and chino did not know when i was going to get one. your motor looks like its in great condition i will keep in touch with you hopefuly we will be able to get together once everything is done and go play hehehe lol should be in sometime this week, how long did it take for your motor to get there
BrownGuy
Jul 17, 2011 04:46 PM
SEIDO
SC400 / 300 Classifieds
Oct 9, 2009 09:52 AM
MadMaxxNA
Aug 9, 2005 03:50 PM
MadMaxxNA
Jul 17, 2005 08:46 AM
