Supra Springs and Struts Change
Old Dec 5, 2005 | 09:13 AM
VQT's Avatar
VQT
Default Supra Springs and Struts Change
How many SC owners in this forum change their suspension to Supra suspension? I hear that it will lower the SC 1/2 in, did you like it and did you have to adjust any camber at all?
Thanks,
Old Dec 5, 2005 | 03:06 PM
Buttercup's Avatar
Buttercup
At least one person did. On my car it was basically 0.6 in rear and 0.4 front on sc300. Somewhat noticeably smaller fender-tire gap. Rides crisper, I have old shocks so I don't know if that affects the ride much. It takes the alignment a little out of spec, so you'll need an alignment job done to bring it back.
Old Dec 5, 2005 | 03:38 PM
SCV8's Avatar
SCV8
It's what should have been on the car to begin with IMO, do a search, there are many who have done this. The main reason I did it was that I had experienced the old rear suspension bottoming out in a hard corner, rapidly overstering, and decided that the original settings were too soft to even be safe.
I went without an alignment for a while after the swap since it was still in the range, but would highly recomend the settings that the Supra guys use, but without the huge camber( better tire wear on the street).
Old Dec 5, 2005 | 09:46 PM
VQT's Avatar
VQT
SCV8,
Do you mean align the SC400 with Supra Srings and struts with 94 Supra alignment specification?
Thanks,
Old Dec 7, 2005 | 04:24 PM
SCV8's Avatar
SCV8
Basically, yes, but I tend to use as close to 0 toe in in front, about a 1/16" in the rear, and 0- 1/2 degree(negative) camber in front, and around one degree(negative) camber in the rear.
Also not a bad idea at all to look for a Supra TT rear sway bar, and mounts to go with your spring/shock setup, also to use an offset, or staggered tire/wheel combo that is similar to the Supra setup.
Old Dec 13, 2005 | 09:04 AM
VQT's Avatar
VQT
Thanks SCV8,
I am still waiting for the Sway Bar end link (could't take the nut out when to allen wrench hole in the stud got bored out) and castle nut to be shipped from Carson Toyota. Will try the alignment spec as recommended. Don't know if I want to spend anymore money for the rear sway bar just yet.
Old Dec 15, 2005 | 09:20 AM
VJ RC51's Avatar
VJ RC51
I'm running OEM lexus struts up front with supra intrax springs
Koni Supra struts and Supra intrax springs in rear.
My car tucks in about 1/4, its LOW, almost too low
Old Dec 20, 2005 | 08:48 AM
VQT's Avatar
VQT
Still waiting for the castle nut and the end link to be deliver, it has been over two weeks already. I still have to get the car alignment and new tires
Old Dec 24, 2005 | 05:45 AM
jdmtruong's Avatar
jdmtruong
i dropped with supra tt shocks n springs. theyre cool. not much of a DROP i shoudl say, but noticably stiffer and space between tire n fender shows less gap. need to go lower
Old Jan 8, 2006 | 12:00 AM
VQT's Avatar
VQT
Can you guy with Supra spring and struts install in your SC400 give me the height (mearsurement) from the ground to the lip of the fender on all four tires?
I changed the front and rear lower control arm with supra springs and struts. The car doesn't seem to be any lower. I forgot to measure the original height before the swap
The car is definitely stiffer, still wait for the new tires to intall to really see any change in cornering capability. My present tires are too worn out to do any sharp cornering
Thanks
dontran
Feb 17, 2013 07:46 PM
stratman3
Nov 13, 2012 11:25 AM
Trevstuh
North Texas Lexus Club
May 20, 2010 10:15 AM
hcfarm
RX - 1st Gen (1999-2003)
Oct 5, 2009 10:39 PM
EvoTuned
Jan 18, 2003 11:38 PM
