6 speed in 99sc300
Old Nov 1, 2005 | 08:34 PM
sxylxy's Avatar
sxylxy
Default 6 speed in 99sc300
Has anyone actually DONE the auto-manual swap on a 99-00 sc300 with the VVT-i and all? I'm finding out through posts about the lack of an ECU to fit this setup but that a supra one may work. Bottom line, has anyone actually done this?
Old Nov 2, 2005 | 03:12 PM
codetoad's Avatar
codetoad
I haven't seen this done before, but thats not to say it hasnt been done. Changing your car from auto to manual is possible. Dosen't the IS300 come with a manual trans and a VVT-i 2JZ? Or is it different. I could be wrong, i've never looked into it, but I would doubt the Supra TT VVT-i computer would work plug and play. It's for a 2JZ-GTE. (Wait did the 98 Supra N/A have vvt-i and a 5sp m/t?)You could always just go with a standalone computer though, if you didn't want to just go ahead and do a full 6spd GTE swap. Someone help this guy out.
Old Nov 2, 2005 | 03:22 PM
kietlander's Avatar
kietlander
Streetking has a 6 speed in his car its a 97.
Old Nov 2, 2005 | 03:29 PM
codetoad's Avatar
codetoad
Yeah, but he has a full GTE swap. He wants to just convert from an auto VVT-i 2JZ-GE to a manual, and wants to know what computer is plug and play.
Old Nov 2, 2005 | 03:42 PM
kietlander's Avatar
kietlander
oops hahah. yeah just use supra ecu.
Old Nov 2, 2005 | 03:48 PM
jpvarghese's Avatar
jpvarghese
Currently there is no standalone that has a full VVT-i function. There are piggybacks out there; but can be expensive. The factory ECU shouldn't be a problem, but can cause headaches in the future when modding; ask Lex Luthor. The only resolution I can see to this if you want perfect factory drivability is to get either a 5-speed IS300 ECU or a '98 Supra N/A 5-speed ECU; both cars have VVT-i. Is it worth it on the long run? Well if you can get everything sorted out; yes; it will be a perfect street machine, but anything over 550-600 whp will cause trouble since there are no aftermarket, large duration VVT-i cams, but there are larger exhaust cams from HKS and is only available on the exhaust side since VVT-i in the SC is found on the intake side. There have been success with e-manage and such. The head will eventually become a restriction when more power is needed due to not enough support for the VVT-i function. I would say your best bet is to find a non-VVT-i SC300 if you want monster horsepower and a VVT-i SC300 if you want a perfect street car. If you want the best of both worlds and have a large bank account, go with a stroker; perfect balance of power and streetability. If all else fails on my part, I'm definitely going stroker, but the problem is that I don't have a large bank account.
-Justin
Old Nov 2, 2005 | 06:38 PM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
from what i understand, going auto to manual the ecu is not a issue.
theres extra software for the auto ecu to control the trans, w/ a manual
trans installed its controlling nothing & doesnt affect its operation.
i've been looking to upgrade to a g-force computer & everyone says
the auto ecu works fine on the maunal trans.
so replacing your ecu is probably not necessary.
search g-force on supraforums & you will see what i mean.
john
Old Nov 6, 2005 | 09:01 PM
sxylxy's Avatar
sxylxy
Thanks for the help. I guess no one has actually done this. That's ok, i'll keep you posted in time. I'm looking for like 350-400hp, I'm going to do the turbo kit all myself, no engine swaps, jsut like a T62 turbo and maybe a little rebuild on the motor. That's the plan with the w58 tranny idealy. This would be a car that could hold it's own but be used for everyday driving too if I wanted to do that. The IS did come with the 5speed VVT-I but I have found out the ECU for the tranny deals with the MAF, intake, exhaust, and an oxygen sensor or two. So I'm not sure, actually pretty sure they're not the same parts on the SC and IS so I'm not sure if that would work. The N/A supra maybe be the way to go, or maybe find someone who can mess with the ECU for me? Eh? Any volenteers?
Old Nov 6, 2005 | 10:50 PM
TurboB6's Avatar
TurboB6
-Justin
Could be wrong but doesn't the Motec M800/880 offer Variable Valve timing options?
Old Nov 7, 2005 | 08:48 AM
Goldark's Avatar
Goldark
haltek AEM MOTEC
all can handle VVTI
tonysc400
Sep 28, 2016 11:52 AM
tsellers
Performance
May 25, 2013 11:40 AM
xsc2jz
Jul 14, 2012 10:49 PM
gsxcody
Mar 9, 2012 09:52 AM
2JZGTSC300
Sep 17, 2009 07:31 PM
