Damned Power Steering (Help!!)
Old Jul 24, 2001 | 08:45 AM
mrKophee's Avatar
mrKophee
My PS pump was leaking so I replaced it (alternator looks ok, if it dies I'll get a new one). I also bled the system but it still makes noise (whines) when I turn the steering wheel, what's the deal? - Any suggestions?
Old Aug 7, 2001 | 12:07 AM
DoubleWhoosh's Avatar
DoubleWhoosh
The system needs to be bled properly, as it is not a normal ps system. There are quite a few more solenoids and such as compared to a basic system.
Also be sure to check the o rings on the lines going to and from the pump...this can cause air to enter the system.
It may work itself out sooner or later from driving though.
Old Aug 14, 2001 | 10:45 AM
LOTC's Avatar
LOTC
VIP 様式
I have the same problem with mines.I just got it repalced and when fill it up with fluid it works fine,but in like 2 weeks the fluid level goes down drastically.I wipe the bottom of the pump and the I find no signs of leaking oil.
Could it be the type of fluid I use?
Old Aug 14, 2001 | 12:19 PM
DoubleWhoosh
If the level is going down, it's almost a given that there is a leak somewhere. You could be having a problem with the fluid foaming up, then overflowing.
There are a couple places that it could be leaking but you won't know just from looking.
tcorder
Aug 26, 2011 05:11 PM
TunerLexx
Jan 11, 2011 10:53 AM
boxcarfan
GS - 1st Gen (1993-1997)
Nov 18, 2010 06:57 PM
Sportznuts
Mar 5, 2007 07:42 PM
robmck
Mar 3, 2001 07:14 PM
