spacers anyone?
Old Sep 17, 2005 | 12:06 AM
DoubleWhoosh's Avatar
DoubleWhoosh
Originally Posted by indelible
what size spacers would go best w/supra TT rims on the SC?
Depends on the tire sizes and if you have the Supra front and rear wheels, or the fronts all around. Let me know and I can figure it out for you.
Old Sep 17, 2005 | 01:51 AM
stevechumo's Avatar
stevechumo
Put the rims on first and see how much more you want the rims to tuck out. Make sure the tires won't rub the fenders when they go over bumps & dips. Also, make sure the wheel nuts have at least 7 turns or more to hold the rims. Less than that, longer wheel studs are mandatory.
Old Sep 17, 2005 | 08:34 AM
sc.Fred's Avatar
sc.Fred
Originally Posted by AutoCoutureSC
if you need spacers, order ones that are HUB-CENTRIC. Todd over at Tmengineering.net should have these.
can you explain "HUB-CENTRIC?" i'm clueless when it comes to spacers, thanks!
Old Sep 17, 2005 | 10:01 AM
DoubleWhoosh
Hub centric means it will have a hole in the center that indexes correctly on the center hub of the brake rotor.
Generic spacers will have a pretty big center hole, which does not center itself. Also most of those have generically sized holes for the lugs - while these are ok, sometimes they can have problems with cracking, or sitting off center and causing imbalance and vibration problems.
They are cheap though but this is another case of you get what you pay for.
I'll post some pictures in a little bit (if that's ok)
Once again also you really shouldn't go more than 5mm for a regular spacer, anything longer might have problems with not letting the hub fit up to the wheel, and also the problem of too short of studs. We have the longer studs though, around $2 each.
Old Sep 17, 2005 | 10:20 AM
Mikethe1st's Avatar
Mikethe1st
Originally Posted by DoubleWhoosh
I think your post/question is more pointless
I think these pictures are very helpful, it's not like these are pictures of a Civic with wheel spacers
Spacer size is confidential anyways
You truely are retarded. You're tying to sell spacers and you say spacer size is confidential. Anyway I asked if you had 15mm spacers/adapters available and still have no answer. Why not post some sc300's with stock wheels and spacers?
Old Sep 17, 2005 | 02:50 PM
PERRYinLA's Avatar
PERRYinLA
Default Attitude check!
Todd (DoubleWhoosh) is anything but retarded- he's more helpful than almost anyone else you can find on this forum. But it's not his job to post pics for you, especially since if you did a gallery search, like I just did, you could easily see some before/after images of wheels with spacers (including a SC).
I'd post some of those spacer pics I just saw, but then, that's not my job, either.
Old Sep 17, 2005 | 04:12 PM
Neo's Avatar
Neo
The One
Mike. Please stop this line of conversation. Just a reminder of a couple of our rules:
Response to Comments
If you have a problem with another member's comments in a posted thread, do not respond with any further comments that will aggravate the situation. Reacting to a hostile post with more hostility puts you in jeopardy, and puts you at risk for action against your account even if it is another member’s fault. Members have two options of recourse:
1. Email the moderators of the forum in which the offensive comment is posted, directing them to the individual and thread in which the problem occurs. Use the "Notify a Moderator" button on the bottom of the offensive post to accomplish the same thing. Moderators will look into the issues and take the appropriate actions.
2. Resolve the problem between both of you via email or Private Message (PM).
Personal Attacks
While we encourage lively debates and discussions, we will not tolerate personal attacks of any kind. Any person attacking another forum member will receive a warning and have their offenses removed. One more offense and the offending member will be permanently suspended from ClubLexus.
We do not allow personal attacks on fellow members. Todd is not only a fellow member but also a CL approved vendor. He has done nothing but help numerous members on CL. If you want clarification on the products, just ask him. There is no need to alienate him and then call him names.
If you have questions, feel free to PM me. Otherwise, let's get back on the topic of spacers.
Old Sep 17, 2005 | 08:02 PM
Mikethe1st's Avatar
Mikethe1st
SKEEEEEEEEEEEEEEET, removed
Old Sep 22, 2005 | 12:17 PM
sc.Fred's Avatar
sc.Fred
double or perry could you post pictures please of cats with stock rims with spacers?
Old Sep 22, 2005 | 02:53 PM
SC400TT's Avatar
SC400TT
Double Whoosh, I have heard that adding spacers effectively resets the wheel Offsets accordingly. Example: If I have a wheel that is +45 Offset, and add 15 mm spacers, then my effective Offset is +30. Is this accurate?
Thanks,
Ryan
Old Sep 22, 2005 | 03:25 PM
DoubleWhoosh
More funny CL typos!
I will try to capture a stray cat here and put some spacers on him!
Old Sep 22, 2005 | 03:31 PM
PERRYinLA's Avatar
PERRYinLA
Default Here's my cat next to stock rims:
Old Sep 22, 2005 | 11:22 PM
DoubleWhoosh
Originally Posted by PERRYinLA
Man if you can hold him there long enough I'll bring some spacers down and we can slip them on his legs
Old Sep 22, 2005 | 11:24 PM
ACleanSC4's Avatar
ACleanSC4
Thanks,
Ryan
I believe that is correct Ryan.
Old Sep 23, 2005 | 08:01 AM
sc.Fred's Avatar
sc.Fred
hahahha! woops.. i didnt even realize that I actually wrote that?!
i jump from looking @ this forum to working so i guess that came out for some reason.. hahah
7MGTEPOWA
Apr 16, 2011 01:44 PM
wongerZ
Jan 28, 2009 06:30 PM
RTIS250
Wheels and Tires Classifieds
Aug 19, 2008 08:32 AM
_adiO
Mar 9, 2008 09:56 AM
