1JZ Spooling Problem
Old Aug 15, 2005 | 08:02 AM
LexSoarer's Avatar
LexSoarer
Unhappy 1JZ Spooling Problem
As I left work this morning to get something for breakfast a 350z jumped on my tail. Thinking this would be a great chance to let him know he bought the wrong car, I punched the gas and started to spool . As I started to build boost, my car sputtered real bad (kind of scared me), and then picked up again. Basically fell on it's face !?! I thought, maybe just a mishap? So.... I decided to give it a go again and it spooled with no problem. Figuring third time was charm, I took off and it happened again. This is not a consistent problem, but it does make me wonder what the problem could be? I figured maybe the plugs were fouled out? But I just replaced those last week with NGK's and had to gap them at .28 so that the car wouldn't sputter at 10-11 psi. Anyone have any ideas??
PS - I have new turbos with about 40k mile on them, but I want to use these as long as possible.
Old Aug 15, 2005 | 12:29 PM
Bean's Avatar
Bean
CL Folding 1,000,000
Do a pressure test, might have a boost leak somewhere! On map based systems you will idle and drive around fine with an intercooler hose popped off; but if you gun it all the boost flies out the system and its basically running NA
Old Aug 15, 2005 | 04:14 PM
got_trd's Avatar
got_trd
It wont sputter like that if he blew an intercooler pipe though. It just wouldnt go past 0 on the boost gauge. I'd check the shaft play
SupraDremr
Apr 11, 2014 06:31 PM
IneednSC
Oct 22, 2012 02:12 PM
shonuff53
Apr 6, 2011 07:39 AM
stillfly45
Nov 8, 2010 08:30 PM
ucfa4
Feb 18, 2008 09:28 AM
