Noise Coming From Suspension After Spring Install
After re-installing my new Eibach and Tokico springs and struts yesterday, I notice my car creeks and “bongs” over bumps and dips in the road. I checked over everything to make sure it was screwed in tightly and torque to specs.
Strange thing is, I didn’t encounter this noise problem when my friends and I had accidently reversed my F and R springs two days ago. After getting the springs the right way yesterday, I notice this problem (most of the sound is coming from the front suspension).
Does anyone have any suggestions? Only thing I did different the second time around was leave ¼-1/2” inch gap from the bottom coil and lower strut cap end – as suggested by Eibach. Anyone encounter this problem? Are there suppose to be rubber isolator pieces on the bottom of the springs? The noise is ruining the driving experience.
FYI: I bought the parts for MKIV Supra to put on my SC3 and the drop is PERFECT. The front and rear’s are even in wheel gap, the tires sits a tad in the fender walls.
Please learn to search....this question has been asked several time before....
Go to this page:
https://www.clublexus.com/forums/search.php
and type "eibach noise supra" in the "Key Word(s)" field. Select "SC 400/300 Models" under "Search in Forums". Then click the "Search Now" button. You will find your answer in one of the four threads.
If you are too lazy to do that, then you can click on this link:
https://www.clublexus.com/forums/sho...ch+noise+supra
Go to this page:
ilmilktea
Suspension and Brakes
May 1, 2009 09:33 PM
PhantomZX
Oct 1, 2003 05:53 PM
