Shifting Problem!
Old Aug 6, 2005 | 10:16 AM
got_Remy's Avatar
got_Remy
Default Shifting Problem!
hey guys, this just started happening yesterday. So i gets in my car and tried to shift my gear from P to D. but it didn't want to go....i had to shift it with using the override button....can anyone tell me what is the problem?
Old Aug 6, 2005 | 11:38 AM
np20412's Avatar
np20412
Is the light in your dash that shows brake light bulb out? There should be an light in the dash, to the left of the P that shows the car, and the rear has what looks like smoke coming out but its for the rear brake lights. If all of your rear brake lights are out for whatever reason, the car WILL not let you shift. no brake lights = no driving. There is a fuse for the rear brake lights somewhere, but I am not sure of where it is. but you have to check that fuse out, someone somewhere will know where it is. Another thing is, when you push the brake pedal down, there is a sensor that unlocks the shifter when the pedal is depressed enough. You may need to have this replaced if your brake lights are functioning properly. When the car is normal and working fine, after you depress the brake pedal a little bit, if you do it slowly, you can hear and feel a click in the shifter, which is the release of that lock which keeps the shifter in P.
Old Aug 6, 2005 | 11:43 AM
got_Remy's Avatar
got_Remy
NYLEXSC thanks so very much... ijust took my car to the shop....they said exactly what you said..i had to fix the light sensor or something it only cost 50 buks.... thanks anyways..
chetmehta
Jun 6, 2019 10:24 AM
BostonBill
Sep 1, 2010 10:37 PM
ES-3
Sep 2, 2007 09:53 PM
EBMCS03
Suspension and Brakes
35
Jun 7, 2006 09:56 AM
may30
Oct 3, 2005 07:28 PM
