Need quick answer about serpentine belt.
Old Jul 28, 2005 | 09:16 AM
LeXuSrAcIn's Avatar
LeXuSrAcIn
Default Need quick answer about serpentine belt.
Mine fell off because one of the pulleys (or tensioner) just fell to the ground. I've been searching and everyones saying its a 5 min fix. My question is... do I need to take out the fan that is attached to one of the pulleys? I have included in the picture which pulley has fallen off by the question mark. Where I have the number 1 is where the fan is attached. Do I need to remove the fan? Finally can someone tell me how the pulley I have noted with a question mark is attached since one day I just opened my hood and saw the pulley on the floor and my belt off the pulleys? Any quick answers will be appreciated as I really need to get this car back on the road.
Attached Thumbnails Need quick answer about serpentine belt.-drive-belt-gs300..jpg
Old Jul 28, 2005 | 09:48 AM
got_trd's Avatar
got_trd
Looks like you need a new crank pulley. You dont need to take off your fan or fan pulley to change a crank pulley.
Old Jul 28, 2005 | 11:28 AM
LeXuSrAcIn's Avatar
LeXuSrAcIn
So the pulley I have circled is the crank pulley?
Old Jul 28, 2005 | 01:47 PM
got_trd's Avatar
got_trd
yes. i hope your not driving it like that
Old Jul 28, 2005 | 01:55 PM
/Aerostar\'s Avatar
/Aerostar\
How can he drive like that? The crank pulley powers everything via the belt doesnt it?
Old Jul 28, 2005 | 02:15 PM
LeXuSrAcIn's Avatar
LeXuSrAcIn
Well it came off and I got it back on along with the serpentine belt. I am getting noise now when I turn on the a/c. I am going to be ordering a new serpentine belt along with that pulley. That is why I needed to know the name. I"m going to see if the belt and crank pulley fix the noise issue. If not then I guess I need to get a new tensioner.
Old Jul 28, 2005 | 02:17 PM
/Aerostar\'s Avatar
/Aerostar\
You sure its not the AC compressor makin that noise?
Old Jul 28, 2005 | 02:33 PM
Cloud9's Avatar
Cloud9
dang..this is the third time I read about this happening. Is it a common problem in the SC? Maybe I should replace mine just to be safe...
Old Jul 28, 2005 | 02:35 PM
got_trd's Avatar
got_trd
oh it'll drive alright.... just not very long, and your engine will get hot quick
Old Jul 28, 2005 | 02:39 PM
FloridaSC's Avatar
FloridaSC
A new s-belt shouldn't even take 5 min to install; maybe like 45-60 seconds. Just loop it around everything except the tensioner, then use a wrench to compress the tensioner, slip the belt over, and there you go. Took me longer to type than install.
I can't believe the crank pully fell off- DAMN!
Old Jul 28, 2005 | 04:20 PM
LeXuSrAcIn's Avatar
LeXuSrAcIn
I dont think its the compressor. The AC works fine but it makes that noise. I'm thinkin it is the belt and crank. The car has almost 250k now and who knows how long it has been since something was replaced. I'm going to Pep Boys right now to buy the belt and see if they have a pulley too. BTW how is the crank pulley held in place? I can't see any place for screws. Do I have to buy the whole assembly or somthing?
Old Jul 28, 2005 | 04:21 PM
LeXuSrAcIn's Avatar
LeXuSrAcIn
Well the problem I had was the steering wheel wouldnt turn, so I couldnt really drive the car.
Old Jul 28, 2005 | 05:09 PM
got_trd's Avatar
got_trd
thats cause w/ out the belt you have no power steering
Old Jul 28, 2005 | 05:32 PM
/Aerostar\'s Avatar
/Aerostar\
or alternator or anything, hopefully you wrent drivin it around with the crank pulley off. And the crank pulley is held on by a bigass bolt (22mm i think?) torqued to something like 250 lb/ft
Old Jul 28, 2005 | 05:49 PM
na4now's Avatar
na4now
Default That tensioner pulley.
A little off topic..But, A pulley was making some noise from the front of the engine on my sc300. I realized it was the tensioner pulley.
So I changed it w/ one I ordered from PeP-Boys. It lasted about four days, before the bearing started making noise.
Yesterday I changed that one out, and its already making noise. (like a dry bearing noise) Now Im thinking of just pressing a new bearing into my factory pulley. Any thoughts?
Jordan
