help! engine shuttering
Old May 28, 2005 | 10:56 PM
Coolstr85's Avatar
Coolstr85
Default help! engine shuttering
ok, so i washed my engine today. nothing serious, just a quick spray down with the hose. i stayed away from the most of the electronics and just generally sprayed the dust off of. when i started my car it started right up but as soon as i started driving it ,it kind of started studdering. i drove it about 5 miles up the street and it shook and shuttered the whole way there. any ideas of what it could be?
Old May 28, 2005 | 11:58 PM
bmatsu's Avatar
bmatsu
More than likely you got water inside spark plug ports and it is messing up your spark plug wires.
Check your spark plug ports and see if there is any water in them.
If there is just use as shop vac (Just tape a long straw to the vacum hose.) and vacum out the water and dry your spark plug wires. Probably your #3&4 plugs.
This has happened to a lot of people who washed / hosed down their engines.
I hope this helps
grumpi300
May 15, 2014 08:29 PM
vipman806
GS - 1st Gen (1993-1997)
Sep 1, 2011 12:49 AM
TLsc300
Aug 28, 2010 04:57 PM
snamen
Jun 29, 2010 06:16 PM
udfxrookie
Mar 27, 2006 02:46 PM
