Tramlining problem
I have a serious tramlining problem too. The car feels kinda scary to cruise on straights because any imperfection on the road seems to knock it off course of just the slope of the road will pull the car to the right. Its kinda bad to the point where I drive <50mph on the streets lol. My car has 135k miles.
So the best bet is to replace the lca with the front Supra LCAs and steering rack bushings?
Is it necessary or would it be a big improvement if the upper arms bushings and the rears be replaced too?
Would tie rod end bushings and upper arms
Just read all the posts.
Originally Posted by mikeloc24
it IS negligent, and at $210 per arm it's considerably cheaper than it's Lexus counterpart.
Ok, so with the upper control arms, would it be a better choice to just replace the bushings or the entire arms. The reason why Im asking this is because alot of people on here seem to agree that its easier and more cost effective to get the Supra LCA than to replace the bushings - and deal with the struggle to get the bushings in and out - or gettin the Lexus OEM arms.
If somebody could confirm that the Supra LCA has the same bushings as the Lexus LCA then I may have gone that route.
The only reason I would have gone withthe Supra LCA is if my ball joints were confirmed as being in bad shape.
Once you have the suspension apart and on a bench the replacing of the bushings is very easy.
Takes all of about 10 minutes per bushing.
Rob
I've gotten quotes last week for just replacing the LCA bushings and the lowest is $200 and the highest was $500 (Luxury Motor Works). The cheapest quote to replace the steering rack bushings was $60 which is also the same price to install a whole new rack?!
I'm going to have the work done @ Harding's Automotive in South Gate and I'm sure there are plenty of people out there who can vouch for the ride of these SC's after fixing these problems.
Ok, so with the upper control arms...
GSTYLIN
Jul 29, 2009 08:44 AM
