Ran into problem while cleaning TB and changing spark plugs
Old Apr 17, 2005 | 07:45 PM
laxdude362's Avatar
laxdude362
Default Ran into problem while cleaning TB and changing spark plugs
While I was putting everything back together after I had cleaned out my TB and changed out my spark plugs, couldn't figure out one thing. Can't think of the name but it's the wire that connects to the gas pedal and when pressed down opens up the TB. I can't figure out how to reconnect the wires and all. Are there any diagrams or pictures that could help me out? Any input is appreciated.
Old Apr 17, 2005 | 08:46 PM
ki_soarer's Avatar
ki_soarer
that would be your throtle cable. you have to push the lever on the side of the TB, to open the flap, then slide the end of the cable into the small hole. release the lever and the make sure the cabel is in the groove. its prety self explanatory as it only goes on one way. good luck.
kennyRX300
RX - 1st Gen (1999-2003)
Apr 21, 2014 03:48 AM
PhreshhWun
Sep 12, 2011 04:35 PM
pcpitstop
GS - 1st Gen (1993-1997)
Aug 5, 2010 06:00 PM
DKSc
Apr 3, 2010 06:29 PM
PlatSilvSc
Maintenance
Jan 7, 2007 12:07 AM
