i know the supra TT and the old LS works on the sc300...has anyone tried using the new LS430 calipers on the Sc300? if so, is it directl bolted on like the supra and older LS ones?
They can fit but require an adapter and a slight bit of machining of the caliper..
Let's put it this way: If you've ever bled your brakes, and you're still alive, you can probably tackle this job.
If you think bleeding the brakes is done by slashing the brakelines, you've got some reading to do.
