Parts Numbers help ? ! ?
Would anyone know the part numbers for the Seat Heater Switches (mounted on the center console) and for the 97+ Lower Door Mouldings (not the side skirts)?
Has anyone installed aftermarket Seat Heaters using the OE Switches? Any info would be greatly appreciated.
I install aftermarket seat heaters in my shop and you can use any switch you want as long as you know how to wire it. It is farly easy as long as you have the switch figured out. If your installing aftermarket seat heaters there are alot better looking switches out there than the factory ones. Does the car have them already? If not the switch looks better mounted on the seat near the power switches and not in the center like the factory does it. It looks alot cleaner and they dont accidently get bumped on as easy.
damon1964
06-17-07 09:35 AM
