heater control valve question
Old Nov 26, 2004 | 03:43 PM
Din's Avatar
Din
Default heater control valve question
I am in need of jsut the plastic valve, i have called 2 local dealers and they both told me that i need to order the whole unit which is around 300$. Does anyone know where i can just buy the plastic valve part?
Old Nov 26, 2004 | 10:13 PM
THE_CEO's Avatar
THE_CEO
Default Re: heater control valve question
if im not mistaken the whole valve is somethere around $270.00...that was the first replacement part i did!...was you car not putting out heat?
CEO
Old Nov 26, 2004 | 10:36 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
probably leaking coolant. that's the "other" part of their failure.
Old Nov 27, 2004 | 12:42 AM
Din's Avatar
Din
yeah its leakin coolent. I ordered the plastic valve for a supra thought it would of been the same but its differnt. Sucks casue the Lexus part you have to buy the whole thing.
Old Nov 27, 2004 | 12:48 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
i sealed mine with *liquid nails* two years ago and it hasn't leaked since. I just removed it and rubbed it around the pole at the base so it would seal, and it hasn't leaked since two years later. Dunno if you will have the same luck or not.
Old Nov 27, 2004 | 10:58 AM
Din's Avatar
Din
mine is leaking where it turns to open the valve at.
Old Nov 27, 2004 | 12:54 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
yep, that's where the o-ring always fails.
pisteuo46
Dec 22, 2014 09:42 PM
joliroger4
Mar 15, 2012 06:44 PM
sc400guy
Maintenance
14
Jul 6, 2008 05:42 AM
neo_tran
May 10, 2002 08:58 AM
