Trouble code 14
Old Nov 10, 2004 | 04:36 AM
Derf's Avatar
Derf
Default Trouble code 14
I am running a obd I computer on my 97 sc300 and I have started getting trouble code 14, ignition signal. When I first start the car it runs fine untill it warms up. Then I get the check engine light. Does anyone have any suggestions where to start.
Old Nov 10, 2004 | 06:11 AM
qtb33's Avatar
qtb33
Put in the correct ECU. Some of the senors don't work from OBD-I to OBD-II. Not to mention it's Illegal if you have any concerns in that area.
Old Nov 10, 2004 | 09:51 AM
abboushi's Avatar
abboushi
you can go to autozone and get OBD2 checked for free, 96-2000 = OBD2 92-95= OBD1
http://www.troublecodes.net/Lexus/
thats the link to what the code error means. good luck
Old Nov 10, 2004 | 10:19 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
I think that was the blinker fluid code.
( i am of no help here)
Old Nov 10, 2004 | 10:25 AM
mikeloc24's Avatar
mikeloc24
yep, put in the right ECU.
Old Nov 10, 2004 | 11:14 AM
Derf's Avatar
Derf
1. Swap OBDII ecu back in? No, I will swap obdII computer back in for emission testing only. Then back to obdI. OBD I lets you tune the car better, at 18 lbs of boost I run 450whp with a nice 12 to 1 air/fuel. Besides my car is very illegal - no cats, open wastgate - so one more thing no big deal.
2. I had already found that code 14 is ignition signal. I was looking for more information on what to check. I have already checked the coil and wiring for something disconnected. I think the problem is with the magnetic pick up on my distributor. Need to do more research.
thanks
Old Nov 10, 2004 | 11:35 AM
mikeloc24's Avatar
mikeloc24
Originally posted by Derf
1. Besides my car is very illegal - no cats, open wastgate - so one more thing no big deal.
Ahh, so I see...well good luck then
08X3
RX - 1st Gen (1999-2003)
Oct 29, 2016 07:59 AM
BigRon239
Mar 19, 2013 11:59 AM
phongX11
Apr 5, 2011 04:04 PM
soarer13oy
Aug 29, 2009 04:57 PM
