New Strut Bar...
Old Nov 22, 2004 | 07:24 AM
  #31
qtb33's Avatar
qtb33
I tried to put mine on this weekend and I need to use about 3-5mm spacer to get it to clear the intake mainifold. Looks like it time to break out the welder.
Old Nov 23, 2004 | 08:39 PM
  #32
vududoc's Avatar
vududoc
just a couple of things to add.
that bar may be made for the soarer vice the SC.........different manifold dimensions.
another thing that may work is when applying the bar jack the car up when installing.
this may give you the space you need as the suspension towers will bow. then torque it down in a suspended state only lowering after. See if that works.......
Old Nov 23, 2004 | 09:47 PM
  #33
qtb33's Avatar
qtb33
I installed while on a lift. Not even close. I see what your saying about the bar flex, I'm assuming thats what your getting at. I may go for the soarer thing though.
Old Nov 25, 2004 | 04:22 AM
  #34
bean_8044's Avatar
bean_8044
Only reason why it would fit a Soarer over a SC is because of the 1JZ's intake manifold. Otherwise its the same exact car....for the most part. If you have the 1UZ or 2JZGE then it might not offer any greater chances of fitting. Not too sure that it needs a tower bar either. It seems to be pretty stiff up front from the factory
Old Nov 25, 2004 | 12:07 PM
  #35
Ice350's Avatar
Ice350
Default strut bar
I don't know about the other guys but I want one for show more than go. It looks cool. That's all....that's all there needs to be too.
You're right though, I think the car is pretty stiff already.
Brands
Oct 6, 2020 07:57 PM
troner
Nov 9, 2011 04:57 PM
over40driv
Apr 29, 2009 09:59 AM
hobojoe
Apr 11, 2009 11:23 PM
ACleanSC4
SC400 / 300 Classifieds
Jun 4, 2004 02:01 PM
