computer and TPS questions
Old Aug 22, 2004 | 11:15 AM
nick778's Avatar
nick778
Default computer and TPS questions
On a '95 sc400, where is the computer? I have been told it is under the dash on the passenger side but even after taking off the glove box, etc, I can't locate it. Also, is the computer OBD I or II for this year?
On a seperate issue, does anyone have the ohm and voltage specs (and which terminals on the TPS to connect to) to check out the TPS and the setting if it is is replaced with a new one?
Thanks....
Old Aug 22, 2004 | 08:32 PM
0l33l's Avatar
0l33l
95' was the last year for OBDI
Old Aug 23, 2004 | 08:19 AM
ChrisK's Avatar
ChrisK
nick778,
ECU is under the passneger side floorboard/firewall area. Try this link for location and removal instructions.
95 SC400 is OBDI as 0l33l mentioned.
Old Aug 23, 2004 | 09:09 AM
nick778's Avatar
nick778
Many Thanks for that link. I'm trying to pull any stored codes. On e.g., Nissans you can turn a screw and the CEL or computer will flash the codes. Is there such a way to do this with the SC400 computer? If so how. Again, thanks...
Old Aug 23, 2004 | 09:44 AM
aliga's Avatar
aliga
Former Sponsor
you need to get a scanner or use the paperclip, you will not getting anything by pulling the ecu
daveskates
May 19, 2021 08:40 AM
xspsi6
SC400 / 300 Classifieds
Nov 24, 2015 08:05 PM
phillup23
Oct 28, 2014 01:56 PM
Maeve
CL of Southern California
Aug 18, 2012 07:54 PM
