Electrical problem?
Old Jul 30, 2004 | 09:35 AM
JSC300's Avatar
JSC300
Default Electrical problem?
Hi, i have a 1995 SC300 5sp. I have noticed this problem for a while now, here is what happens:
when i use anything power like turn on the lights, turn on the ac, turn signals, wipers, even hit the brake my cars power flickers and it resets my radar detector and makes the car bog down a little. this also happens when say im slowing down for a redlight, i will put the car in neutral and when my RPM's hit idle the cars power will dim and come back on, making the car bog down.
I took it to a toyota specialist and he checked the wiring and even replaced the battery, but its still happening. Its driving me crazy! Could it be the alternator??
Thanks. Justin
Old Jul 30, 2004 | 10:00 AM
SupraCoup3's Avatar
SupraCoup3
do you have a sound system or anything? Any extra load on the electrical system?
Your alternator may be suspect... but also make sure your car has a good solid ground (although your tech most likely already checked).
Old Jul 30, 2004 | 10:04 AM
JSC300's Avatar
JSC300
just have the stock sound system no sound upgrades at all
Old Jul 30, 2004 | 11:06 AM
mikeloc24's Avatar
mikeloc24
check your negative ground, that's what was happening when I had this exact problem. Your issue appears to be the same, check the grounds and check them well, also spray some terminal protectant on your battery terminals.
then do a search for "electric ghosts" and read up....
Old Jul 30, 2004 | 11:14 AM
jeremyp111's Avatar
jeremyp111
This is a very common problem. I went through it when I got my SC4 back in April. Remove and clean all of the terminals very well and make sure they are tight. Check the negative cable for any corrosion. Report back.
BTW, a grounding kit made a big difference for me as well.
Old Jul 30, 2004 | 11:33 AM
0l33l's Avatar
0l33l
Sounds like a bad battery to me. When I went to look at the SC that I got, it was sitting with a dead battery. The guys tried to start the car with another battery attached to to the one that was in there and the lights flickered, even the cluster.
Old Jul 30, 2004 | 01:00 PM
SupraCoup3's Avatar
SupraCoup3
Old Jul 30, 2004 | 02:11 PM
0l33l's Avatar
0l33l
Originally posted by SupraCoup3
That should teach me to read the entire post before replying
Anyway, a new battery can still be faulty. Do you see a battery warning indicator when you turn the car on? If the battery is good, then its the alternator
Old Jul 30, 2004 | 08:26 PM
JSC300's Avatar
JSC300
thanks for the replys guys. i'll spray some terminal protectant on the battery terminals this weekend...where are the grounds located
Old Aug 1, 2004 | 03:48 PM
rscott's Avatar
rscott
A magic 3 wires upgrade might do the trick also. Use some heavy gauge wire (i used 4 gauge) to connect the following spots:
alternator post -> (+) battery terminal
chassis -> (-) battery terminal
engine -> chassis
The last one i did in a couple places just to be sure there was a good connection. Hope it helps.
peeplwtchr
GS - 1st Gen (1993-1997)
Aug 30, 2011 07:54 PM
scfocus
Aug 4, 2008 12:23 PM
yusef
Feb 29, 2008 05:33 AM
LexGsBoi
Apr 27, 2004 12:17 PM
wim
Feb 17, 2003 05:47 PM
