Lowering issues continue: ( when does it end )
Old Jul 26, 2004 | 01:45 PM
  #31
EUROJulian's Avatar
EUROJulian
Specs are (`92 SC400)
Front: 7.654" (.."....mesure from the ground to the center of the lower suspension arm mounting bolt"
Rear: 9.909" (..."...from the ground to the center of No2 lower sus. arm mounting bolt.")
Nazty, granted that you have messured correctly you have some real drop there ...
(...NOW specs are given for factory tire setup. You should correct specs for loaded diameter difference between your new and oryginal wheels...)
Solara350
Suspension and Brakes
Apr 29, 2017 06:08 AM
SpmMorrow
IS F (2008-2014)
13
Jul 8, 2013 11:18 AM
streetx
IS F (2008-2014)
Apr 24, 2013 10:49 AM
Peter_Klim
Apr 17, 2010 10:25 AM
MongooseGA
Nov 14, 2009 05:26 PM
