SC400 front Caliper removal issues
I tried to remove the calipers from the car with a socket wrench. I purchased some penetrating oil...that didn't work...after 2hours, i quit.
This car was in Mass. for some time, so i guess a slight amount of rust as formed...It's only a 97 but ?..
Since i could only local an impact wrench at a friends house out of town..my next option was a breaker bar..I purchased a breaker bar with a 1/2"(not paying attention late at night). I had to get a 1/2" > 3/8" converter..I was getting exciting..thinking i could get them loosened up..I sprayed it down again with PB blaster oil...I thought i snapped the bolt head...instead it was the converter..known to be weak link.
http://216.77.188.54/coDataImages/p/...6818owned2.jpg
Sunday, i tried locating a socket that would fit the 1/2" drive but there weren't any...
I bought a heavy duty converter with a life time warranty.
The guy at the store said to heat(via torch) the surrounding area and keep applying pressure.
If the front calipers are so hard to get off, I can't imagine what i'm going to go through for the rear rotors removal.
On a side note, i tried loosening the bolts on the caliper..because i will be doing the brakes when i change the rotor....well, I used a normal socket wrench with a smaller converted and did this..
http://216.77.188.54/coDataImages/p/...6819owned1.jpg
Maybe it was a fluke thing..last saturday night...but...my car is only a 97...WTF?..I shouldn't have this much rust trouble!
Any advice would help.
BIGD
what bolts are you trying to get off? that is snapping those parts? the 14mm caliper bolts?
are you sure you are loosening them and not tighten ... go counter clock :P
can you get a deep socket 14 - 1/2?
I don’t really recommend using a wrench and then hitting it with a 3lb sludge.
all mine came off without any problems
www.harborfreight.com
i bought a few breaker bars of different sizes, 1/2" drive impact sockets, 3/8"->1/2" adapters (so i could use the sockets on a regular rachet, 1/2"->3/8" adapters(so i could use regular sockets on the breaker bars), and a clicker torque wrench. I stay away from those 1/4" little sockets, ive gone through so many of those in my earlier days i could probably fill my trunk. Theyre cheap for a reason.
I remember both times..trying counterclockwise..and very rarely clockwise....don't tell anyone....
again..BIGd
oh my god...I think i remember trying to loosen it like a lug nut...but now that i think about it..it facing the opposite direction...i think i tried both directions before quitting.....
again..BIGd
let us know if you get them off
again..BIGd
. Good luck getting em off
again..BIGd
BTW, I didn't have near as much trouble removing calipers as you. But then again a Texas car= no road salt.
The rotor was changed in 20min. The brake install was harder than expected...usually i just pry the pistons back between the pad and the piston..but..they extended back out slowly, by the time i got the new EBC green stuff brakes in...i had to work at it to get it back..but i got it done in 1.5hrs..
I took it around the block...yes..with only one installed...for the people who have slotted brakes...is that clicking noise normal?...i assume it's the brakes sliding over the slots....Will it every go away?
All i need now is a few nice gold LEXUS logos to go on to the stock calipers.
the Chrome version of my current rims are coming next week.
Here are some pictures..
Thanks for everyone's help...even on the stupid problems i had!
BIGd
