need help regarding bride seats
Old Jun 14, 2004 | 12:33 PM
TopSCecreT's Avatar
TopSCecreT
Default Need help regarding bride seats
wsup guys, i didn't kno where to ask this so i come here:
i will be buying bride seats from Sexy10 from the IS forums and i am wondering if the rails/brackets from the IS will fit on the SC......will i need to modify them? or should i might as well get new rails? need help ASAP.
thanks,
Pat
Old Jun 14, 2004 | 01:57 PM
SupraCoup3's Avatar
SupraCoup3
if they fit the MKIV Supra, I'd say they're a direct swap. People put the stock MKIV seats into the SC quite often.
John
Old Jun 14, 2004 | 02:54 PM
TopSCecreT's Avatar
TopSCecreT
Thanks John, so i'm guessing that i should get the seats without the IS rails and just buy MKIV Supra bride rails?
I still want to kno if the IS rails will fit into the SC, it'll be cheaper for me if i get the seats with the rails already, new rails cost around 200 per seat
Old Jun 14, 2004 | 03:04 PM
rscott's Avatar
rscott
what you could do is see if the IS guys ever use supra seats and rails in their cars. If they do, then theyll swap over.
Old Jun 14, 2004 | 04:02 PM
TopSCecreT's Avatar
TopSCecreT
kool, thanks
Old Jun 15, 2004 | 01:02 AM
drnkcarlos's Avatar
drnkcarlos
If your fitting a Bride seat then you will need either a #ZZ30, JZA80(MkIV Supra) rail. I searched long and hard on Yahoo Auctions Japan to find my rails and they will work for either SC300 or MkIV Supra's. The IS rail is a bit different. Attached is a pic of a IS rail. Also make sure you buy the correct rail for your bride seat. If you bought the Brix2/Ergo2/etc.. seat you will need the newer seat rail (believe its a MO rail) as the older Bride rails (which is a S type for recliner) ,although more plentiful, will not bolt up to the New Brix2 series seats. Good luck with your purchase. Hope you can find rails cheap enough.
Attached Thumbnails need help regarding bride seats-sxe10_3629-img600x450-1087132848dscf0002.jpg
Old Jun 15, 2004 | 09:15 AM
TopSCecreT's Avatar
TopSCecreT
Thanks drnkcarlos!! taht helps me alot, i'll be getting the Brix, so i'll also be getting the older rails
i'll post pics when they are on the car
Old Jun 15, 2004 | 09:23 AM
ACleanSC4's Avatar
ACleanSC4
I just bought some Bride sliders/brackets for my car Pat for the Recaro seats I got. They are on order right now and should be in any day...
PM me if you want to know how much I paid for the pair of sliders/brackets.
jonherrera
Jul 8, 2014 09:35 PM
PseudoK
Apr 19, 2013 09:43 AM
chaacmool1
Sep 5, 2011 06:54 PM
Star08
Apr 5, 2008 08:35 PM
mungrin
Dec 6, 2004 10:24 AM
