What does a kick-down switch do?
Old Jun 13, 2004 | 09:26 PM
DIrEctQL's Avatar
DIrEctQL
Chicago Lexus Club Moderator
Default What does a kick-down switch do?
I'm trying to figure out what the kickdown switch does. Aparently early SCs had one but in like 95 or 96 it was removed.
Chris
Old Jun 14, 2004 | 06:49 AM
ChrisK's Avatar
ChrisK
Chris,
From my understanding the kick-down switch forced the transmission downshift an additional gear.
Old Jun 14, 2004 | 12:01 PM
VSsc400's Avatar
VSsc400
where is the kick down switch?
Old Jun 14, 2004 | 04:56 PM
DIrEctQL's Avatar
DIrEctQL
Originally posted by ChrisK
Chris,
Chris,
Do you have one on your car? I got a kickdown switch from a '94 Toyota Supra TT. It fits right in but I am not sure if it's installed right. I have to floor the gas pedal to hit the kickdown switch.
Chris P.
Old Jun 14, 2004 | 04:58 PM
DIrEctQL's Avatar
DIrEctQL
Right under the gas pedal. The SCs without one (like my '97) should have a plastic filler plate in place of it because the transmission doesn't need one. I have Supra TT transmission which requires one.
Chris
Old Jun 15, 2004 | 06:10 AM
ChrisK's Avatar
ChrisK
Chris,
I don't have one. I also have a plastic filler plate. I believe yours is installed properly. You only should hit it when flooring the gas pedal.
Old Jun 19, 2004 | 06:35 PM
P.Williams's Avatar
P.Williams
My '94 SC400 has one. I didn't realize what it was at first, but could feel it when I'd floor the gas. One day I took a gander beneath the pedals and saw it. I figured it did just what ChrisK stated, dropped the tranny down a gear. As far as whether yours is installed properly, I notice that after the switch is depressed and the tranny shifts, the switch seems to rise back up slightly. That's what I noticed which caused me to investigate. It's kind of a strange feeling, but it seems to force the pedal back up a bit. Hope that helps.
Old Jun 19, 2004 | 09:44 PM
P.Williams's Avatar
P.Williams
Default Kick-down switch mods
Hmmm....Now you've got me thinking. If the kick-down switch under the gas pedal tells the auto tranny to drop down a gear, would it be possible to splice into the wiring and place an additional switch on the dash/console/steering wheel? My SC400 is the only car I've owned that wasn't a manual. I thought I'd never buy a car with an automatic. Luckily, the V8 has enough grunt to make it liveable. However, I still get a bit frustrated trying to power out of corners and not be in the right gear. If I could get it to down shift without having to floor the gas pedal, I might be a bit more satisfied. Also, do the later cars without the kick-down switch still have the wiring for the switch? If so, owners of later cars may be able to rig up a switch of this sort. Does anyone know why Lexus got rid of it?
Old Jun 20, 2004 | 10:42 AM
DIrEctQL's Avatar
DIrEctQL
Default Re: Kick-down switch mods
Hey,
The kickdown switch is a simple on/off switch. That means there is a wire going in and a wire going out. It should be possible to relocate it. The newer that don't have the switch do not have the wires so you run them yourself. Then again, why would you run them if the ECU can't regulate it.
Chris
02Ku
Aug 2, 2021 02:48 PM
jp1guy
GX - 1st Gen (2003-2009)
May 15, 2017 09:28 AM
Sherwink
RC - 1st Gen (2015-present)
Mar 27, 2015 06:49 AM
clean
GS - 1st Gen (1993-1997)
Aug 23, 2008 11:30 AM
