Eibach Pro kit for Supra TT. Drop on sc?
Old May 22, 2004 | 08:33 PM
mrshabo's Avatar
mrshabo
Default Eibach Pro kit for Supra TT. Drop on sc?
I was told that the eibach pro kit for the supra tt drops our car around 1.9-2 inches, can anyone confirm this?
Old May 23, 2004 | 03:08 PM
P.Williams's Avatar
P.Williams
I've got the Supra TT Eibach Pro-kit matched to Supra Bilstein shocks on my SC400. The car is definitely lower than the 1.5/1.1" advertised drop for the Supra. About 2" in front, 1.5" seems about right. However, I installed the Daizen front and rear camber kits set at 2 degrees front and 1.5 degrees rear. I just had the car aligned and they were able to adjust fully within the recommended ranges for all settings. I'm pretty happy with this setup with my 18" wheels. It's definitely much firmer, without being uncomfortable. I have noticed that at highway speeds on certain roads, it can get a bit bouncy.
Old May 23, 2004 | 03:59 PM
mrshabo's Avatar
mrshabo
how much were teh camber kits? do you really need them? how would a regular camber kit compare to the daizen camber kit? what is the difference.
Old May 23, 2004 | 05:36 PM
AutoCoutureSC's Avatar
AutoCoutureSC
only camber kit is the daizen camber kit. you can only adjust so much on stock camber. hehe, did you get my PM? i think i explained everything.
Old May 25, 2004 | 07:04 PM
2jzsc3's Avatar
2jzsc3
Default Re: Eibach Pro kit for Supra TT. Drop on sc?
awwww.. you don't take my word for it? haha.. well i'm sure you'll get confirmations from everyone that is using this set up..
Old May 25, 2004 | 07:18 PM
mrshabo's Avatar
mrshabo
lol i believe you, i'm just trying to find reasons to get out of buying the camber kit lol. 300 bucks + installation sucks... just to make my tires straight.
Old May 25, 2004 | 11:12 PM
P.Williams's Avatar
P.Williams
I'm not sure how much you can get away with lowering the car, and avoid a camber kit. My alignment printout showed that only my right front wheel was outside of the specified range before they performed the alignment (that was with the camber kit installed.) It was about a half a degree out. Without the Daizen kit that would have been 2.5 degrees beyond the most extreme recommended setting! I don't know how close they would have been able to get it without the camber correction. Negative camber in the 2-3 degree range is what drift cars often run. With the kit installed, they were able to set everything pretty much dead center within each of those ranges, and even set a little less negative camber on the left side to account for driver weight.
Not only do you have the camber setting of each particular wheel to consider, there are also things like cross camber that have to be addressed. So, you won't be able to just slide the adjustment bolt all the way over to eat up as much of the negative camber as possible. They may need to even add a bit of negative on one side for the sake of cross camber, to help keep the car from pulling one way or another on the road.
If you're looking for cost effective Supra springs , check out the Tein H-Tech springs. I don't remember what the advertised drop is for those, but is was under an inch. I want to say that it was .5" front, and .4" rear. It will be lower on the SC, but obviously not as low as the Eibachs. I just put Tein H-Tech's and Bilstein shocks on my IS300. I am in love with these springs. They noticeably lowered the car, but it's nowhere near slammed. The ride comfort is definitely still there, but roll during cornering was drastically reduced. If I'd had these on my IS before I lowered my SC400, I probably would have opted for them over the Supra TT Eibach Pro-Kit I put on. One word of caution however, Tein is trying to phase out the H-Tech springs and is pushing the S-Tech series which is lower and stiffer. So, a lot of places that list the H-Tech's don't have them in stock. They are on backorder indefinitely from the Tein warehouse. Options Auto Salon had the IS kit in stock at a decent price. Or you could check eBay. They're typically more affordable than the Eibachs.
Old May 30, 2004 | 09:00 AM
abboushi's Avatar
abboushi
my car has close to a two inch drop. i was expecting 1.5 i alos have the eibach prokit (supra TT0 and bilstein shocks(supra TT) it sits pretty low and I like it.
Old May 30, 2004 | 09:02 AM
abboushi's Avatar
abboushi
Default Re: Re: Eibach Pro kit for Supra TT. Drop on sc?
2jzsc3's word is good. very knowledable in this field
Old Jun 11, 2004 | 04:04 AM
ant1k's Avatar
ant1k
how is the ride with the eibachs??????smoothe????
Old Jun 11, 2004 | 10:54 AM
2jzsc3's Avatar
2jzsc3
excellent ride quality. I'm running TT eibachs with AGX adjustable shocks and I'm lovin it!
Old Jun 13, 2004 | 09:34 PM
TGRich's Avatar
TGRich
PM siniquezu
He may have a set of eibachs for sale at a good price
Old Jun 16, 2004 | 03:36 AM
chitwnsazn's Avatar
chitwnsazn
the car hasn't started sagging?
LazyAlex
Apr 18, 2006 04:22 PM
jbiel
Oct 15, 2005 11:32 AM
RADSC
Apr 21, 2005 07:34 PM
ScottURnot
Oct 12, 2004 04:59 PM
Lexgendboi
Aug 10, 2004 06:00 AM
