Turning off Traction Control
Old Apr 25, 2004 | 01:24 AM
c33w's Avatar
c33w
Default Turning off Traction Control
Hi, I am a new member on this board.
I own 2 1986 corolla gt-s, a 1995 supra NA, they are all RWD.
I am able to lose traction on all except my sc400. Ever since I got my 1993 sc400, I have been trying to "drift" my sc400.
Anyway, can anyone tell me how to turn off the traction control. If the traction control can not be turn off by the ecu, I will disable it by other means.
Thanks
Old Apr 28, 2004 | 09:07 PM
Project300's Avatar
Project300
Look on the console to the right of the shifter. Push the "trac off" button and you will disable the traction control until the button is pressed again or you restart the car.
As for drifting, if you really want to get the back end free you might want to look for a "positraction" rear end so that both wheels can get power to the pavement evenly. I'm not sure, but the Supra's rearend should have what you want. With the stock rearend, the wheel with less traction will just spin.
Check for posts on this in the Suspension section.
Happy drifting!
Old Sep 13, 2010 | 07:46 PM
karl300's Avatar
karl300
Does anyone know if it is possible to permenatly turn off the traction control in the sc400?
Old Sep 13, 2010 | 07:48 PM
nivek5sfe's Avatar
nivek5sfe
i think there is a fuse you could remove for this
Old Sep 14, 2010 | 07:59 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
you could remove the trac control relay in the engine bay its the box with 4 large relays.
2 are for ABS and 2 are for Trac control, however all 4 may have abs written on them (they are the same type of relay more or less). you could remove the 2 for the trac, i believe its labeled inside the cover for the relay box. you may get a Check engine or Trac light, and you alone are completely responsible if you mess anything up.
ZISF
Jan 4, 2018 11:35 PM
mr2fast4u
Dec 26, 2009 06:02 PM
italiandud
Aug 27, 2007 05:18 AM
i<3lexus
Jan 23, 2005 07:06 PM
