S-AFC questions.
Old Jan 28, 2004 | 05:51 PM
Dimcorner's Avatar
Dimcorner
Default S-AFC questions.
I have dynoed my car with stock exhaust and brought it down to -10% after 3000rpm to bring the A/F ratio to about 12:1.
Now i have exhaust and it seems to miss up top. I don't think it's detonation because it gets worse if I add fuel to it. Could it be something else?
THanks
Old Jan 29, 2004 | 05:45 AM
BLK13X's Avatar
BLK13X
For Mind Cruising
Which S-AFC do you have? The simple one or one of the more recent ones (blue screen type)? It's been discussed in the ALSC that the Soarer TT runs rich (the majority of the richness) in the midrange of the revband... is this the problem?
Old Jan 29, 2004 | 09:17 AM
Dimcorner's Avatar
Dimcorner
blue screen one...
Seems then that is ok. I was worried because -10% is quite alot. I took out about 10% from 3500rpm all the way up to 7500rpm.
Thanks for you input.
Old Jan 30, 2004 | 11:58 AM
VSsc400's Avatar
VSsc400
i have a walbro 255lph high pressure intank pump and the blue screen S-AFC on a 92 sc400
i have -14% Corr @ 4500rpm
Old Feb 1, 2004 | 05:08 AM
Frankinaustin's Avatar
Frankinaustin
Default Timing
Does the SAFC offer adjustments to timing as well? What ab out shift points on the auto tranny. I'd like to raise my shift points - so if there is a thing out there that does that, kindly let me know.
frank
Old Feb 1, 2004 | 02:12 PM
aliga's Avatar
aliga
Former Sponsor
afc does fuel tuning only. as for tranny shifts, there is a post about a tiptronic type controller at lextreme.com
Old Feb 3, 2004 | 05:59 AM
BLK13X's Avatar
BLK13X
For Mind Cruising
Frankinaustin,
The S-AFC is a fuel controller. To control ign. timing you'd need at the very least an A'PEXi ITC (Ignition Timing Controller/Converter), which is a piggy-back ECU, or go the whole hog and replace the factory ECU with an aftermarket one (e.g. Motec, A'PEXi PowerFC, HKS F-Con V etc.). Also, on the topic of changing the shift points, if you're just looking to raise the shift point flick the ECT switch into Power mode , but if you're interested in quicker shifts for the auto box have a read of this...
Planetsoarer.com - Shift kit & transmission cooler info
Hope that helps you.
Jose
AdvanSLF
Jan 26, 2014 05:13 AM
CP_Ree
SC400 / 300 Classifieds
Jul 20, 2009 11:31 AM
Dx3
Jun 4, 2009 08:35 PM
Kavistar
May 24, 2006 10:15 AM
